Removal of Fuel Pump
William2 wrote:Is it possible access-wise to remove the AC glass bowl type of fuel pump from an S4 Elan for replacement or repair? My car doesn't have any cut outs in the fibreglass transmission tunnel for access.
Yes, I've done it many times, as far as I know only the Sprint has a cutout in the f/glass with a grommet in it but it does not really help even with the grommet removed.
When you refit the pump just make sure you get the operating arm on the top of the cam and not under it.
Note: sometimes it is easier to remove the engine mounts to get the engine slightly over.
i have a 1972 Sprint and no cut outs.
- alan.barker
Well my Oct 72 Sprint has this hole opposite the fuel pump with a grommet in (grommet removed in pic) and I assumed all Sprints had it.
I remember another thread where it was mentioned.
lotus-chassis-f36/holes-footwell-what-which-t31036.html
you are right Brian. I have just looked on my Sprint and there's a rubber bung.
I have never seen it before
- alan.barker
terryp wrote:My Fed S4 has the bung ..... does that mean its a Sprint?
No......it probably means my 72 Sprint is a S4 despite the rear lip,the diff brace, the paint job,the bv cam cover, the Delorto's and a 72 chassis number etc.. etc....
