leak from choke retaining screw
PostPost by: batfish » Sat Jan 03, 2015 5:09 pm
Just found out where the petrol on the underside of one of the carbs is from. They are 45dcoes and the fuel is from one of the choke retaining screws. Not investigated much further yet but any ideas why this is happening and any possible solution.
Andy
batfish
PostPost by: batfish » Mon Jan 05, 2015 3:52 pm
I think I have found the reason for the leak. I have a TTR airbox and the thickened flange on the carb intake trumpets are recessed into the backplate, this prevents the fixing tabs from pressing against the flange and pushing the trumpet up to the venturi. 2 of the trumpets are clamped firmly in the correct position but 2 are looser and can move out 3-4 mm leaving a gap to the venturi. When I removed the loose trumpets there was petrol between the carb body and the trumpets. Problem is how to clamp the trumpets tightly up to the venturis when the flange is recessed
Andy
batfish
PostPost by: patrics » Mon Jan 05, 2015 10:29 pm
I had this problem with my TTR airbox - I made new clamps with a bent bit to hold the trumpet in.
If the trumpets move to far there is a risk it will cover the main jet.
patrics
PostPost by: batfish » Mon Jan 12, 2015 4:20 pm
Problem solved as Steve suggested, made some new clamps with a lip long enough to press onto the flange on the trumpet.
Andy
batfish
