STAINLESS WEBER FUEL LINE FITTINGS
PostPost by: silverlink » Thu Sep 25, 2014 3:45 pm
Have searched the web to no avail trying to find stainless connectors and unions for my Sprint Webers. I can get the blue/red and black anodized ones but there doesn't seem to be anyone who does Stainless ones. I am wanting to do away with the banjo fittings and fit a flexible type like I had some years ago from Christopher Neil Sportscars (theirs were blue/red anodized) It seems I need -6 fittings and Aeroquip, Earle's and Goodridge only do them anodized. Goodridge did do an Historic range which were aluminium which would do but I understand they've now dropped that range. Any ideas guys?
Ian
silverlink
PostPost by: pharriso » Thu Sep 25, 2014 8:41 pm
What about these http://qedmotorsport.co.uk/qed-shop/lotus-twin-cam/carb-ancillaries/braided-fuel-line-various-types from QED?
I've had a set for a year... satisfied myself :D
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: gus » Thu Sep 25, 2014 10:40 pm
http://www.ebay.com/itm/like/261600139372?lpid=82
https://www.google.com/search?q=stainle ... 6066118997
you can buy build it yourself kits with JIC swivels and any of the above
In this country mcmaster carr sells the hose and fittings
gus
PostPost by: silverlink » Fri Sep 26, 2014 5:18 pm
Thanks for your replies guys,
Unfortunately the parts you recommend are all of the banjo type and I'm trying to avoid using them. I have a guy at CAM Products from Hertfordshire who are main Goodridge agents looking into this for me in the hope he'll come up with the goods.
Ian
silverlink
PostPost by: bitsobrits » Sat Sep 27, 2014 1:48 am
When I can't find anything other than the red or blue anodized fittings, I bead blast the color away (except on the threads) then polish them up in natural aluminum. Have also left them matt finish, and oiled.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
bitsobrits
PostPost by: silverlink » Sat Sep 27, 2014 7:21 am
Funny enough Steve we tried this on my old setup and it worked, I think you may be right with your suggestion.
Ian
silverlink
PostPost by: gus » Mon Sep 29, 2014 1:33 pm
http://www.mcmaster.com/#jic-tube-fittings/=txlv21
zinc plated steel
http://www.summitracing.com/parts/rus-6 ... 7Aod9yIADg
black
http://www.stainlesssteelfittings.com/M ... s-9605.htm
p/n SS-9605-04-L06-12
stainless
I dunno, like the way a 90 degree banjo dresses the lines
gus
