Strombergs
I have recieved the alternative CD175 CARBS, but struggling to work out what type they are. Apart from the obvious (CD175) the choke mechanism operates a bar that raises in the housing lifting the needle approx .8cm.
The main reason for enquiry, I have (only on one) near the adjustment screw a brass right angle block with a small guage brass pipe approx 3cm long, i have no ideas what this is for. Stupidly did not take photo before i put them on, will however try to take picture.
Many thanks
Many thanks
- Ennva
Difficult to say without seeing it but the first thing that occured to me is whether it's a DIY method of checking the fuel level in the float chamber.
Re Identiying the new carbs, I was going to suggest buying a copy of the Haynes Stromberg book - until I had a look on Amazon. ?88 new! Even a secondhand one covered in oily fingerprints is going for ?35. If you're ever in my part of Oxon (Thame) you're welcome to use mine to check the carbs.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
