Weber Cross Drilling size?
PostPost by: AHM » Sun Jan 05, 2014 2:43 pm
Hi All,
Having discovered that the cross drilling under the carb is blocked, I have taken out the lead plugs.
Before I dash in with a drill... What diameter are the ducts? What size lead shot do I need to get to plug them again?
DSC_0572.jpg and
AHM
PostPost by: Craven » Sun Jan 05, 2014 3:51 pm
3mm. long series drill required. Usual one to be blocked is the choke supply.
Melt a scrap piece of lead for plug.
PostPost by: AHM » Sun Jan 05, 2014 9:33 pm
Thanks.
It was the choke as you say - absolutely solid both sides. Easy to clear with a hand held drill bit. Unfortunately my smallest extra long drill is 3.2 so clearing the vertical duct was a little harder.
AHM
