Lotus Elan
Easy weber mixture tool
PostPost by: rcraven » Mon Oct 14, 2013 8:12 am
What's the rib bone?
Robert
rcraven
PostPost by: MickG » Mon Oct 14, 2013 8:51 am
That's connected to the back bone.
MickG
PostPost by: GrUmPyBoDgEr » Mon Oct 14, 2013 9:08 am
twincamman wrote:Oiiiiiii....runners make headers ...that run into 4 into 2 into 1 collectors and that runs into the exhaust tube ........and that's attached to the rib bone....this causing me exhaustivity
It's hard work on 'ere 'innit Ed :wink:
Beware of the Illuminati
GrUmPyBoDgEr
PostPost by: AHM » Mon Oct 14, 2013 10:13 am
Ed. What sort of temperature difference between the runners are you considering reasonable/acceptable?
AHM
PostPost by: twincamman » Mon Oct 14, 2013 10:38 am
All around 460 F.....try to make them as close as you can...... around the bend
twincamman
PostPost by: AussieJohn » Mon Oct 14, 2013 11:15 am
Is "runner" Canadian for what USA people call "headers" and UK people call "Exhaust Manifold" ?[/quote]
And Australians call "extractors"
AussieJohn
PostPost by: elansprint71 » Mon Oct 14, 2013 11:24 am
MickG wrote:That's connected to the back bone.
Obviously:
http://www.youtube.com/watch?v=Dc9cNHZFTts
PostPost by: twincamman » Mon Oct 14, 2013 3:32 pm
No there are 4 runners to a manifold (5 if you drive an Audi or 8 if you drive a chebby)
twincamman
PostPost by: Tahoe » Mon Oct 14, 2013 5:01 pm
I'm a runner. Don't run as much as I used to when I regularly ran in 5 and 10 k events.
How Bizarre :? :!:
Tahoe
PostPost by: twincamman » Mon Oct 14, 2013 5:29 pm
Ok. Serious for a moment A cold engine at idle after a 2 minute. Idle was 438 degrees ....across the runners ..headers .. Collectors.. pipes ...round things bolted to the head exhaust thingies
twincamman
PostPost by: jk952 » Mon Oct 14, 2013 10:26 pm
Ed,
Thanks for the approximate target temp. info: at about what distance from the head/manifold flange do you measure, I tried this before some time ago and found the temp. drop vs dist. significant, rather logically as Spok would say. Is about two inches correct, before one gets into additional metal affecting heat dissipation and since runers join at diff. places need to not get too close to that). If too close to the head does the head cooling affect it? I have stainless headers, not stock cast ones.
Jack
ps: fellow canuck, understood the lingo :)))).
Note,
Just reread, you said "around the bend... "
jk952
PostPost by: twincamman » Mon Oct 14, 2013 11:30 pm
As long as your distance is the same for all readings it is irrelivent ...I stand and aim .....like the urinal ....Temperature is temperature?..and around the bend is where these guys are sending me aaAAAAAAAAAAaA.... :|
twincamman
PostPost by: nomad » Tue Oct 15, 2013 1:57 pm
Mannn.........this English is a tough language!!!!! :lol:
Country's separated by a common language and all that.........
Kurt
nomad
PostPost by: twincamman » Tue Oct 15, 2013 4:45 pm
weLL i threw the ball through the window and it was light enough to hit the llight ..Idont envy any one whos mother language isnt ENglish.....
twincamman
PostPost by: Jaybee » Sun Oct 20, 2013 11:22 am
I'm lost its a 40+ year old engine seems a bit over the top!
Jaybee
First Gear
First Gear
PreviousNext
