Easy weber mixture tool
• Page 1 of 3 • 1, 2, 3
Buy a remote thermometer , the one with the lazer beam ...focus on each runner and match the temperatures by setting the mixture and balance screws ......Ed
The round tube that RUNS from the exhaust port to the collector. There are 4 measure each one ..they should be the same temp as the gas runs through them
The piece of tube gathering the 4 exhaust tubes attached to the head
Cooled down by CliveyBoy!
Pistacchio sprint 72 - Fourth Gear
What's the use
What's your experiences using a remote thermo? Happy? What make model? etc.
I have one but have never used it on the TC engine. Will try it later.
Thanks for the heads up.
AB...
AB...
Alex Black.
Now Sprintless!!
Now Sprintless!!
Ok, i always wanted to know but never dare to ask... If that?s a thermometer on my ear where is my pencil?
twincamman wrote:The round tube that RUNS from the exhaust port to the collector. There are 4 measure each one ..they should be the same temp as the gas runs through them
Is "runner" Canadian for what USA people call "headers" and UK people call "Exhaust Manifold" ?
I believe the assembly of runners and collector is the exhaust manifold.
'67 S3 SE FHC
'67 S3 SE FHC
BTW, it's the relative temperature of the runners that's important here so even if the emissivity is not spot on, the relative temperatures should still be valid - assuming there's a similar amount of rust on each tube in the exhaust manifold!
'67 S3 SE FHC
'67 S3 SE FHC
emissivity ......
Not a bad word for a Sunday by the way...
Al' ....
Al' ....
Alex Black.
Now Sprintless!!
Now Sprintless!!
Oiiiiiii....runners make headers ...that run into 4 into 2 into 1 collectors and that runs into the exhaust tube ........and that's attached to the rib bone....this causing me exhaustivity
