no fuel in carbs
Galwaylotus wrote:For static ignition timing I rigged up a light (12v bulb with cables and crocodile clips soldered to the two terminals). Connect one side to the earth side of the coil and the other to a good earth. Rotate the crank until the timing marks line up with 10?BTDC or whatever your spec is. Then rotate the distributor anticlockwise until the bulb lights (just). Clamp the distributor and you're ready to go.
Erm should that not be: Until the bulb just goes OUT. !
Seems like it should but no; it's when the bulb lights. When connected as discussed and the points are closed, there are two paths to earth and the 5 ohm resistance in the bulb I'm using must be more than the resistance through the points path. When the points are closed, more current flows through the points circuit than the bulb so little or no light from the bulb. When the points open, all the current must then flow through the bulb and hence it lights!
'67 S3 SE FHC
'67 S3 SE FHC
billwill wrote:Galwaylotus wrote:For static ignition timing I rigged up a light (12v bulb with cables and crocodile clips soldered to the two terminals). Connect one side to the earth side of the coil and the other to a good earth. Rotate the crank until the timing marks line up with 10?BTDC or whatever your spec is. Then rotate the distributor anticlockwise until the bulb lights (just). Clamp the distributor and you're ready to go.
The bulb is wired in parallel with the points and so will light when the points open as the distributor is rotated clockwise.
S4 DHC
S4 DHC
- oldelanman
oldelanman wrote:billwill wrote:Galwaylotus wrote:For static ignition timing I rigged up a light (12v bulb with cables and crocodile clips soldered to the two terminals). Connect one side to the earth side of the coil and the other to a good earth. Rotate the crank until the timing marks line up with 10?BTDC or whatever your spec is. Then rotate the distributor anticlockwise until the bulb lights (just). Clamp the distributor and you're ready to go.
I knew I had a typo in there somewhere! Of course the distributor must be rotated clockwise as the advance comes against the normal operational rotation (anticlockwise in the Elan). Thanks for the correction oldelanman!
'67 S3 SE FHC
'67 S3 SE FHC
Galwaylotus wrote:Seems like it should but no; it's when the bulb lights. When connected as discussed and the points are closed, there are two paths to earth and the 5 ohm resistance in the bulb I'm using must be more than the resistance through the points path. When the points are closed, more current flows through the points circuit than the bulb so little or no light from the bulb. When the points open, all the current must then flow through the bulb and hence it lights!
OOOps, sorry, you are right, the bulb will come ON when the points (or virtual points of a Centronix) open up, .
The setting required is the moment when the points open.
I had just realised that and was coming back here to modify my comment above, but you all beat me to it. My momentary lapse was because I used to do it the other way, removing the lead from the distributor and putting the bulb in series with the coil and the points. But the method described above is easier.
I guess if you snooze you lose on this forum!
'67 S3 SE FHC
'67 S3 SE FHC
