S-4 fuel tank
I've had tank leaks repaired by brazing. Very satisfied. Worst leak was at one of the mounting studs on the tank bottom. Simply brazed it and it was fine. Unless your tank is very rusty and severely, deeply pitted, consider this repair as an option. Roger
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
Elan45 wrote:I've had tank leaks repaired by brazing. Very satisfied. Worst leak was at one of the mounting studs on the tank bottom. Simply brazed it and it was fine. Unless your tank is very rusty and severely, deeply pitted, consider this repair as an option. Roger
Probably goes without saying but be very careful if you are going to attempt to weld or braze the tank - the risk of explosion is high. I have seen a tank explode while being welded and this was despite being thoroughly steam cleaned inside beforehand.
S4 DHC
S4 DHC
- oldelanman
