Fuel tank
I filled car up (shows just over 3/4 full) and it now leaks from the inlet pipe rubber elbow. Seems like when reasonably full, the fuel sits in the elbow. Who would design it like this? Am I just overfilling or is it a feature of the car? Are there known solutions apart from running with half a tank.
Regards ac
1968 Elan +2 Red
1968 Elan +2 Red
acoster - First Gear
acoster,
It's a feature of the car that the fuel sits in the elbow when the tank towards 3/4 full but it will not leak if the elbow is in good condition and the hose clips are tight.
- elanman999
As said, a feature. My filler elbow was very hard and could not be fitted correctly. After replacement it sealed OK. From memory I think it is a 2 1/4" elbow; was able to get one at an industrial supply.
Stu
1969 Plus 2 Federal LHD
If you can soften the elbow in hot water, it should seal well. If you can't soften it, it's too old and needs replacing.
- mikealdren
http://www.ebay.co.uk/itm/57mm-2-1-4-90 ... 983wt_1037
Does anyone know if the silicone hoses are more resistant to petrol? You can buy them in lots of different angles.
I bought a turbo set for my diesel Ford and they were cheaper than replacing the 1 split intercooler hose supplied by the Ford Main dealer (which I sent back).
Jason
Jason
Jason1 - Coveted Fifth Gear
well I bought a silicone hose and am fitting this weekend so will find out. My research suggests you can buy straight fuel and oil resistant hose but the elbows are a bit vague about fuel resistance. Must be better than existing one... I hope
Regards ac
1968 Elan +2 Red
1968 Elan +2 Red
Yes I found out to my cost recently that all of this "rubber-ish" fuel pipe is now only classed as "fuel resistant" and not "fuel proof".
The point being that there are various levels of leakage and it's not easy finding out which has the least.
But obviously anyone with a +2 does not mind the odd smell of petrol anyway.
- elanman999
