Dellorto starting circuit
My +2S 130 with dellorto DHLA's has always been a problem when cold, for the first mile or two it needs a little throttle to stop it idling especialy in cold weather, after this it is fine.
Usually this is not too much of a problem except when I have had a flat battery and have to stop and open the garage door also my wife wants to use it in the summer and this is a real problem for her.
The cold enrichment function does work but seems so rich it doesen't realy help.
I have had two thoughts of how to fix it.
1. Look at the cold start circuit, and possibly fit a smaller jet (any idea what the standard size is?)
2. Give up on the enrichment device and build a variable stop for the throttle pedal which can be controlled by the choke cable.
Has anyone else had this problem and managed to adress it?
Kevin
Kevin
- kstrutt11
Hi. You may find that following the set up procedure in Des Hammill's book "How to build and power tune Weber and Dellorto DCOE, DCO/SP & DHLA Carburettors" will help. If you haven't done this already it would seem that this should be the first thing to do.
Regards.
Sean.
Regards.
Sean.
- alaric
