Stromberg running rich
Just had the spark plugs out of my Elan and the front two are text book sandy brown, the rear two are black. Having read the manual I understand there is no fuel mixture adjustment on the ZS carbs so does this mean a rebuild or could it just be the needle in the rear carb needs re-setting? The carbs were re-built in 1995 when the car was restored (by Peter Day) and have only done 5,000 miles since. So is there a quick fix or do I order a full rebuild kit (?30 per carb) or get them professionally re-done by Burlen?
David
David
Elan S4 DHC
E-Type S1 OTS
E-Type S1 FHC
E-Type S1 OTS
E-Type S1 FHC
- Heuer
Is this something that has just changed recently? Usually when the carbs starts to wear out the various seals to admit more air weakening the mixture. If it's running richer (and you haven't touched anything
) then a few possibilities come to mind immediately. Firstly, have you checked that the choke mechanism is returning to the off position? Check the cable is free and the return spring is working properly.
Next, the extra fuel is coming from the float chamber - either through a problem with the float height or the needle valve. I would have thought though that you'd have noticed something more than just sooty plugs if the prob was in this area - flooding for example.
Thirdly, a problem with the needle. They are adjustable up or down but that's not a tuning aid, it's to allow for eg variation in jet height. If only one carb is playing up it could be a broken needle (not in the bit you see but in the part that's fixed into the air valve. (That was the cause of my running rich problem).
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
What Stuart said, but I'd put a priority on checking the float heights and weights first.
A float that leaks or absorbs fuel will get heavy and ride lower in the fuel... heavier = richer mixture. Weigh both floats on an accurate gram scale. They should both be the spec weight, and they should be the same weight.
Then set the float height. Again, both should be to spec, and both should be the same. Be accurate.
Tim Engel
Tim Engel
- Esprit2
Check the rubber diaphram. Take the rubber and centre boss needle holder out and hold it up to the light. Gently stretch the rubber diaphram and see if there are any holes. Don't remove the diaphram from the centre boss as you will never get it back on, that old they grow.
- ivor badger
Many thanks for the input. I will investigate all these options.
David
David
Elan S4 DHC
E-Type S1 OTS
E-Type S1 FHC
E-Type S1 OTS
E-Type S1 FHC
- Heuer
Users browsing this forum: Robbie693 and 2 guests
