Dellorto jets
Was playing with the slow run jets because it seems a bit rich when ticking over. Borrowed a set from another pair of carbs to try. The installed set of jets are short and look just like a Weber main jet, but the other set have a tube extending out the bottom of the jet. The emulsion tube for the slow runs are also different. One has a jet hole in the top, but the other is blank with an air hole in the side at the top of the emulsion tube.
Is there any mechanical difference between the jets, or are they completely interchangeable?
- ivor badger
Don't know the answer to your question but the guys at Eurocarb will:
http://www.dellorto.co.uk/
They have given me truly excellent service with Dellorto parts and advice. I'm sure they would advise even if you are not buying right now.
Vernon
Vernon
Elan S2 26/5614
Alfa Romeo Alfetta Berlina 1974
Westfield 7SE
Westfield 7SE
- quaybook
