Page 3 of 4
Re: Fuel Mileage - how far on a tank
Sat Jun 19, 2010 11:56 pm
prezoom wrote:Playing with the bleed valve in the bottom of the float chamber can make drastic results in mileage. The accelerator pump moves a lot of fuel every time you move your foot, extra fuel your engine does not need. Saying a steady foot makes for better mileage is spot on. Try enlarging the bleed hole until it starts diminishing your performance. It will help increase your mileage.
Rob Walker
26-4889
On a Delorto, the throw of the accellerator pump is adjustable by two nuts locked together on a screwed rod at the engine side of the carbs.
You have to take them off to get at the adjustment, so it is tedious.
Too little throw & you won't be able to pump the throttle to prime the engine to start it.
Sun Jun 20, 2010 8:42 pm
by alexblack13
It is just possible to adjust them with the carbs on but you need three very small hands!! I have been thinking of replacing the little two nut (lock nut!) setup with a three mm nylock. Anyone done this? It should then be possible with a little ratchet spanner (Got one) to set the throw to suit. My carbs are still very rich on the acc' pump and it is causing a slight rich cut / flat spot. Livable with but could be better.
Alex....
Sun Jun 20, 2010 9:03 pm
by richardcox_lotus
Well.....got back earlier. 246 miles in total, mainly M-Way & Dual Carriageway. Arrived having travelled at a sedate pace (60-70) & then 40 mins traffic jam. Went home & 20 mins traffic jam before plain sailing. So....topped up shortly after leaving the circuit ( I reckon I used between 1/3 & 1/2 a tank on the morning journey), putting in another 16.5 litres. That brimmed it again - & I still have over half a tank left.
So I reckon I would have made it without a fill-up, which is comforting to know the range would probably be 260-270 miles. Also, I concur with the steady throttle position style of driving - minimal inputs as mentioned earlier.
Good to see so many Lotus F1s. Even the 43 ! (Lotus BRM). Such a shame it was sans engine....
If I get time I'll put some pics up.
Richard
Sun Jun 27, 2010 5:06 am
by scott
I put newly rebuilt dellortos on my 1970 s-4se using a 150 hp twincam with a ZF 5 speed and got 6 mpg
I've gradually tuned from there and got 36 mpg when I thought I had it about right. Drove 90 miles today mostly on curvy secondary roads and returned 39 mpg. One plug looked a little lean so I've adjusted that barrel slightly. Think I've got it pretty close now
Scott
Sun Jun 27, 2010 4:10 pm
by Frank Howard
My Stromberg Elan regularly returns 29 miles per U.S. gallon around town. For highway driving, it gets 35. Last weekend, I completed an 800 mile trip in my 5-speed big valve Stromberg Europa Special. Averaging 70 m.p.h., I got 37 m.p.g. Apparently, the extra gear is worth no more than 2 m.p.g. so one of the benefits of performing a 5-speed conversion on the Elan probably deserves reconsideration.
Wed Apr 13, 2011 6:02 pm
by StoatWithToast
I was checking my mpg a lot towards the end of last summer before the car was put away for all the work. I was getting around 32-38mpg depending on conditions and as I knew the engine was being rebuilt I was not very, erm, mechanically sympathetic, shall we say (e.g. only below 5,000rpm when waiting at junctions).
Wed Apr 13, 2011 9:07 pm
by Mazzini
I really would like to hear what owners of Elans with a five speed box and EFI are getting to the gallon.
Wed Apr 13, 2011 9:11 pm
You will shortly,I've just altered my cruising ratio to 16.5:1 and am going to finish this tank full on my trip over to Sheffield tomorrow,going to VOSA as they want to double-check my chassis number...
P.S. I wasn't really doing 95mph on my way to Newark Autojumble Sunday morning...
Shortly
Thu Apr 14, 2011 10:40 am
Not best pleased,just filled the tank and am getting 38.7mpg,was hoping for the upper 40's but there is still room to maneuver yet...
Thu Apr 14, 2011 11:00 am
by gordont
it all sounds way too accurate to me... I get about a weeks driving to a tank...
Thu Apr 14, 2011 11:06 am
by Mazzini
Hi Gordon,
I guess petrol isn't as heavily taxed in Oz as it is in the UK?
All the best,
Louis
Thu Apr 14, 2011 11:53 am
by gordont
AUD$1.50 a litre, issue is more a fuel gauge that is dodgy to say the least!
Thu Apr 14, 2011 12:26 pm
by Mazzini
I'm paying approximately AUD $ 2.10, I think most of that goes to HMG in tax.
Thu Apr 14, 2011 7:56 pm
by Spyder fan
I did 262 miles yesterday just for a service and MOT, topped the 11 gallon tank right up the night before and still have half a tank left. I get way over 40mpg on a run, even when I am baiting the repmobiles who think I'm driving an old and slow sportscar. Perhaps I'm cheating using a zetec with fuel injection?
My old twincam did over 40mpg so long as you didn't go over 70mph on a run.
regards
Thu Apr 14, 2011 8:09 pm
by elansprint71
Fit a diesel.
