Fitting Webers before fitting engine/box to car
I am trying to anticipate any possible problems on refitting the motor/box and I am sure that installing the lower nuts/washers to the back carb will be a bear of a job.Anyone got any thoughts on fitting the carbs before putting the motor in? Too risky?
David
1970 S4 SE with Sprint motor
David
- dpchamp87
Hi Bud,
I will admit to never having done that but I personally would leave off the carbs. I even left out the studs on both the carb and exhaust manifold side & I fitted the studs when I had everything into place. I did have a bit of a tussle with the fitting of the carbs (and manifolds) but its not impossible. Far from it..
That's how I would (will!) do it again if and when I need to.
Have fun and good luck with it..
Alex B.....
Alex B.....
Alex Black.
Now Sprintless!!
Now Sprintless!!
I have tried it a few ways over the years snd have settled on the following when I remember it and dont do thinghs out of order
1. Gearbox in first
2. Then assembled engine including engine mounts without carbs or exhaust or dizzy but otherwise complete. I drill out the eingine mount bolt holes to the chassis so easier to line up and fit the bolts
3. Bolt the mounts in place then fit starter, carbs, dizzy, in that order
4. Then clutch slave assembly and fit exhaust to head in that order. Depending on exhaust style and chassis you may need to mount exhaust loosely in place before bolting the eingine mounts to the chassis.
1. Gearbox in first
Bud,
its clear that everyone has their own way of doing it! I would put as fully complete an engine in as possible, leaving off only the dynamo and starter. Remember to connect the incoming fuel line before even looking at engine mountings. The clutch slave is easier if done before the exhaust and the exhaust before that side engine mounting. The last one in is the dynamo.
Once you've managed to line up the engine/gearbox - everything is easy!
Peter
Peter
- Allison
