petrol fumes in boot
Bandjie,
Yes, from my experience some petrol smell is normal. But it can also be caused by leaks, in the tank, in the filler pipe and in the vent tubes. So if bad it does need investigating. Now you'll say whats bad, you need to compare against another +2.
Take the trim panel covering the tank off and check that the vent tubes are connected etc.
- elanman999
Yes, petrol fumes come as standard...
Mine smells worse when garaged and with a full tank of fuel. Since there are no apparent leaks, I assume it is the (original) breather pipes - they don't look like they are made from fuel-compatible material. More like the plastic tubing you can buy at aquatic shops...
I have bits of air cleaner foam in the ends of the breathers to try to stop evaporation losses, but they often end up soaked in fuel after a fill-up...
Hope to try the Spyder-type breather mods 'one day'. Linking the filler neck to the top of the tank should help 'eliminate' another annoying standard feature: s--l--o--w fill-ups...
Matthew
Matthew
- ppnelan
Check all the posts on this one. There are very few hoses that are not permeable to unleaded petrol. I made up a test loop a few years ago; the only "hose" which didn't give off a smell was teflon lined. All the other elastomers allow for a certain amount of permeation resulting in a smell. I guess that's why most modern cars have all the plumbing on the underside of the car.
Gerry
Gerry
- gerrym
Well Gerry, that's a very fine piece of knowledge for us to remember.
From my point of view, I'm prepared to believe it.
When I leave the boot of my Sprint closed for some time there is a very strong petrol smell when I open it. I now have the habit of leaving the boot open when parked in the garage and there is no obvious petrol smell.
Perhaps I shall explore the posibility of using Teflon in the boot as I am running 3 bar pressure.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
I did the Club Lotus mod as mentioned by Brian and this has reduced the fuel smell in and around the car to a point where it is no longer an issue. The downside is that it takes even longer to get the tank topped up to anything like full. Just don't join the filling station queue behind a Plus 2!
Wylie
Wylie
- ebc699
HI
I found a "bit of a smell" in the rear is normal but much worse when one of the vent pipes fell out of its grommet it the bottom of the seat belt space by the side of the rear seat (drivers side). used tie wraps to ensure pipe stayed firmly in its grommet and now as I say just a "bit of a smell"
Hope this helps
Bob
Hope this helps
Bob
- bob_rich
When I converted mine to a cabriolet I obviously had to remove the original vent pipes, I therefore joined the two vents together using 10 an 15mm copper pipe and short lengths of rubber hose from the tank to the pipe, the other end I then fitted in the filler neck just below the cap using a brass water tank fitting, I then soldered a single small bore pipe (brake pipe) in the top of the main pipe and vented this out below the floor.
Since doing this I have never had any fuel smells.
- kstrutt11
I get more petrol smell when the tank is full and the windows open..
The discovered petrol was sloshing past the filler cap seal and dribbling down the rear wing. Then the car aerodynamics seemed to be pulling the vapour back into the car..
1972 +2S130
tdafforn - Fourth Gear
