terryp wrote:I have a hesitation from idle but only when the car is super warm , does that mean I'm too rich?
How long have you got?
The only short answer is that it is one possibility.
I am not an expert here, but my limited understanding is that there are several things that could be causing it.
Idle mixture is one - and definitely worth experimenting with if you do have a colortune or something else that allows you adjust it reproducibly. You can get into all sorts of trouble if you just go randomly tweaking different screws and lose track of where you were.
You might have an imbalance or some other adjustment wrong which means that one or more of the carbs is idling on the progression circuit instead of the idle circuit, which will impair the take-off from idle.
Also, the ignition advance has a big effect - check the timing.
Float level also affects it - after braking hard I get a lot of hesitation initially because the levels change in the float chambers.
All of that is before you start to look at the accelerator pump and other jetting.
With the colortune one thing you can do is to drive the car until it is hot and showing the problem, then fit the color tune and have a look at what's going on under different conditions of idle, slow take-off from idle, and fast take-off from idle. The colour you see tells you something about what the carbs are doing under each condition and may give you a clue. The colortune instruction leaflet gives some useful information on how to interpret the different conditions.
Paddy
