cleaning external carburettor body
Tue May 26, 2009 5:48 pm
by RichC
just had a go with some dilute ammonia and it cleaned them up a treat . just ordered some aluminium cleaner from The Polishing Company - hope it does what it says on the website!
Re: cleaning external carburettor body
Tue May 26, 2009 8:55 pm
by Jason1
Have you tried carb cleaner? I would be cautious about using anything that could damage the carb gaskets and seals.
gordonlund 's +2 always looks spotless under the bonnet, what do you use Gordon?
Jason
Wed May 27, 2009 10:11 pm
by fatboyoz
Rich,
Please keep us posted how you go with the cleaning.
Colin.
RichC wrote:just had a go with some dilute ammonia and it cleaned them up a treat . just ordered some aluminium cleaner from The Polishing Company - hope it does what it says on the website!
Mon Jun 01, 2009 1:44 pm
by Bruce Crowthorne
I had mine stripped, but found that cellulose thinners works a treat!
The thinners is cheap - buy it as "gun cleaner"
Bruce
Mon Jun 01, 2009 5:13 pm
by RichC
thinners is ok if it's just oil based grime . I'm thinking more of the problem of oxidation/encrustation. Anyhow, just opened parcel & will give it a go in 5 mins
Mon Jun 01, 2009 7:47 pm
by dusty
I did mine with some aluminium cleaner I found in the shed with a skull and crossbones on it, don't think you can buy it any more though
Tue Jun 02, 2009 7:02 pm
by Jason1
Halfords sell an aluminium cleaner it is in the motor bike section.
Jason
Mon Mar 21, 2011 11:25 pm
by AHM
I'm looking for a product to brighten-up my carbs.
Has anyone sucessfully used one that can be purchased in the UK?
Simon
Tue Mar 22, 2011 10:56 am
by martinbrowning
Simon,
I use a cleaner called Alu, by a company called Belgom. Paul Matty stocks it. The oil pump and carbs came up very well, and the fuel pump shines almost like chrome.
Just my thought...
Martin
Tue Mar 22, 2011 12:43 pm
by AHM
Hi Martin,
Is it a polish or or a cleaner?
I'm trying to make thenm look as new rather than shiny.
Simon
Tue Mar 22, 2011 2:41 pm
by martinbrowning
Hi Simon,
Good point - on the tin it says that it is a product for cleaning AND polishing. Just lifted a sticky label and found that it is supplied by ABC supplies. Two web sites (currently down for overhaul): www dot picadoreng dot co dot uk and www cetempolishing dot co dot uk.
Phone 01472 824520.
Hope this helps
Martin
Tue Mar 22, 2011 2:57 pm
Tue Mar 22, 2011 3:08 pm
by theelanman
have you tried frosts?....
I get their stuff from time to time and its been very good....
although Ive not tried the Alu poish so I cant comment but I have used their polishing kits for other this to very good effect....
http://www.frost.co.uk/item_Detail.asp? ... =Alu-Magic (250ml)
Wed Mar 23, 2011 3:13 pm
by AHM
Thanks All,
These products sound similar - I've bought the Alu-Magic as it specifically states "desolves aluminium oxide"
Rather than asking and waiting I have decided to put it to the test - Lets see if it does what it claims! I'll take before and after photos.
Simon
Fri Mar 25, 2011 9:56 pm
by AHM
I noticed that Frosts also sell a liquid Aluminium cleaner. Did some research on aluminium brightners andnotice that they all have phosphoric acid as the "main" ingredient.
More research - so does Alloy wheel cleaner (which I had alresdy tried) so I guessed that industrial Alloy wheel cleaner would be a bit more potent and went and bought some!
Here is the trial:
