cleaning external carburettor body
Have you tried carb cleaner? I would be cautious about using anything that could damage the carb gaskets and seals.
gordonlund 's +2 always looks spotless under the bonnet, what do you use Gordon?
Jason
Jason
Jason1 - Coveted Fifth Gear
Rich,
Please keep us posted how you go with the cleaning.
Colin.
Colin.
RichC wrote:just had a go with some dilute ammonia and it cleaned them up a treat . just ordered some aluminium cleaner from The Polishing Company - hope it does what it says on the website!
'68 S4 DHC
- fatboyoz
I had mine stripped, but found that cellulose thinners works a treat!
The thinners is cheap - buy it as "gun cleaner"
Bruce
Bruce
Bruce Crowthorne - Third Gear
Simon,
I use a cleaner called Alu, by a company called Belgom. Paul Matty stocks it. The oil pump and carbs came up very well, and the fuel pump shines almost like chrome.
Just my thought...
Martin
Just my thought...
Martin
- martinbrowning
Hi Simon,
Good point - on the tin it says that it is a product for cleaning AND polishing. Just lifted a sticky label and found that it is supplied by ABC supplies. Two web sites (currently down for overhaul): www dot picadoreng dot co dot uk and www cetempolishing dot co dot uk.
Phone 01472 824520.
Hope this helps
Martin
Phone 01472 824520.
Hope this helps
Martin
- martinbrowning
Its listed here as a polish http://www.thepolishingshop.co.uk/acatalog/Belgom.html
have you tried frosts?....
I get their stuff from time to time and its been very good....
although Ive not tried the Alu poish so I cant comment but I have used their polishing kits for other this to very good effect....
http://www.frost.co.uk/item_Detail.asp? ... =Alu-Magic (250ml)
Thanks All,
These products sound similar - I've bought the Alu-Magic as it specifically states "desolves aluminium oxide"
Rather than asking and waiting I have decided to put it to the test - Lets see if it does what it claims! I'll take before and after photos.
Simon
Simon
- AHM
I noticed that Frosts also sell a liquid Aluminium cleaner. Did some research on aluminium brightners andnotice that they all have phosphoric acid as the "main" ingredient.
More research - so does Alloy wheel cleaner (which I had alresdy tried) so I guessed that industrial Alloy wheel cleaner would be a bit more potent and went and bought some!
Here is the trial:
Here is the trial:
- AHM
