Fuel additives.
My twin cam has a tendency to pink very slightly and only occasionly.Had a good chat with Paul Matty who suggested Millers VPO as the best solution..Any opinions?
Ian.
Ian.
- rocket
I only recommend Sea Foam. I use it in all my MG and my Lotus. Harmless to the fuel lines and engine, removes carbon gently. I use a bottle every 2000 miles more or less.
Carlos
Carlos
Carlos A - Third Gear
rocket wrote:My twin cam has a tendency to pink very slightly and only occasionly.Had a good chat with Paul Matty who suggested Millers VPO as the best solution..Any opinions?
Ian.
Yes - use Tetraboost.
- hatman
Ian millers is good but quite expensive per tank fill i use castole valve master does quite a few tankks of fuel & they do one with an octane booster which is slightly dearer available from Halfords about ?10
Ian
Ian
- elansprint
I've been using Valve-Guard (ELF). Bought quite cheap from fleabay. Cannot say it is better or worse than any of the others, but as it comes from ELF I guess it must have some sort of credibility.
The only reason I use it is to create the 100 Octane fuel for which the engine was designed.
Maybe I'm just kidding myself but the engine seems to perform much better when dosed-up.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
Brian,
Have you a link to that ebay item?
Thanks.
Stuart.
Thanks.
Stuart.
- stuartgb100
Stuart,
I could not find the link to what I bought and the name does not compute in eBay at this time. However, there appears to be a good deal going on a Texaco product that should be OK.
http://cgi.ebay.co.uk/TEXACO-LEAD-SUBST ... 240%3A1318
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
I'm with elansprint, Castrol Valvemaster Plus, valve seat protection (not that I'm convinced you need it with a twink) plus an octane boost. Comes out well in independent tests and is far far cheaper than Millers because of the mixing ratio.
The best of course is real lead (so Tetraboost these days) but if you want something cheap and easy it's got to be Valvemaster Plus
I have used Millers since the lead went out of the pump "pencil" and the car runs great - particularly with the Shell high octane stuff. I have returned the car to the original static ignition timing which was not possible with the old 4*.
Ian
Ian
- ianf
I used to use Castrol ValveMaster with Octane boost but still suffered Valve Seat regression (I didn't have hardened seats in those days). Have used tetraboost ever since)
- richardcox_lotus
I need to get some more Tetraboost - does anyone fancy splitting a consignment with me, handover at Donington perhaps?
- hatman
