Essential and recommended tool for balancing the mixtures
I assume the rain has stopped, then
Thanks, I'll see what I can get hold on, locally.
Bjorn-Anders, Norway
'95 Caterham Seven Roadsport
'02 Elise Supercharged
ex Europa S2
ex Elan +2S 130
ex Esprit Turbo
ex Caterham SS
Life is too short to drive boring cars
ex Europa S2
ex Elan +2S 130
ex Esprit Turbo
ex Caterham SS
b-havers - Third Gear
Whilst I appreciate this could balance the mixtures between cylinders to some degree, does a higher temperature indicate a weaker mixture and conversely lower temperature richer mix between the cylinder being compared with?. I ask this as I am aware that it is possible to find, in a diesel engine, a cylinder / injecter that is not running correctly by monitoring the exhaust temp. in comparision to the other exhaust temps. The load on a diesel has a dramatic effect on the exhaust temperatures, high load = high temp.
Regards John.
Regards John.
The lines fall unto me in pleasant places, yea I have a goodly heritage.
- redskatejbf
You're spot on there John. After a good run yesterday I put the thermometer on the manifold and 1, 2 & 3 were showing approx 192 to 197 degrees whilst 4 showed at 234. Pulling the plugs it was immediately obvious no 4 was a touch leaner than the others, so I have screwed it out an eighth of a turn and will recheck them later.
Earlier in the day on those setting by the way, the car was on the engine tuner and was showing a CO of approx 3.0 to 3.2, which I believe is about right.
Now the mixtures are hopefully sorted I have also swapped the BP5ES plugs I was running (to stop it coking up at slow running) to BP6ES to see whether that makes any difference (the recommended BP7ES used to choke it dead.)
Mark.
Mark.
M.J.S - Second Gear
Hi, M.J.S.
The temps. you obtained are / would be a good ball park figure for someone to aim for ( I havn`t tried it ) but did you check immediatley after the run? I would imagine the temps. of the exhaust would rise very quickly in still air and give a false impression of cylinder temps. Hopefully this rise would still be relative to the exhaust gas temperature in the respective cylinder / s. as the water and head temperature would rise in tandem.
Next time you check, please report back , and see if the temps. rise dramatically when you leave it ticking over for several minutes.
If this is another means of setting / checking air / fuel ratio between cylinders cheaply I think it would be a great advantage to us paupers.
A great pity that Kieth Frank does not post here anymore, he would indicate if we were going up a blind alley.
Regards John.
Regards John.
- redskatejbf
Users browsing this forum: mark030358 and 15 guests
