Essential and recommended tool for balancing the mixtures
Posted: Tue Aug 19, 2008 11:40 am
This is with thanks to John P. Clegg for suggesting it to me, cheers John.
It deserves to be wider known.
Buy an Infrared Thermometer and use it to measure the exact temperature of the exhaust manifold pipes an inch or two from the head.
It gives a very good indication of the fuel mixture each cylinder is burning. You can adjust the mixture screws and see the difference it makes to the temperature with far more accuracy than a colortune.
It allowed me to finely balance the mixtures across all 4 cylinders and make a major improvement to a lumpy idle, and so easy to use.
It does not allow for the balancing of the carbs though! Mixtures only.
Maplin have one on special offer for ?19.99 which is where I bought mine; again thanks John for putting me on to it.
You can probably also use it to spot vampires and zombies, then use your finely tuned Elan to run them over and save the world.
Mark.
Mark.
