Strombergs v. Webers Advice please
I am of course NOT in anyway biased (!!!!) but I think the highest roadtest top speed in period on a standard car was for an S4 SE coup? on Strombergs. Indeed there are those who would suggest that the ONLY reason the Elan Sprint had a lower 0-60 time was its use of a lower rear axle ratio (to overcome the extra weight - they did it again with the Elise...), although I'm sure the go-faster stripe down each side will have helped.
Enough worms in the can yet?
Tony (S4SE coup? and early model S1 Elise....)
1969 Elan FHC S4 SE
- tonycharente
OK, OK you guys have persuaded me. Instead of wasting money on my fuel guzzling, overrated Dell'ortos, I shall ditch them and go Strombergs.
I know it is a small chance, but perhaps someone can be tricked into trading me straight up .........
- elancoupe
elancoupe wrote:OK, OK you guys have persuaded me. Instead of wasting money on my fuel guzzling, overrated Dell'ortos, I shall ditch them and go Strombergs.
Very kind, but No thanks - I forgot to mention that with a RHD drive car the Strombergs also ease access to the brake and clutch master cylinder top-up caps and to the distributor. I suspect the Stromberg set-up is also a fair bit lighter, easier to balance, harder to flood.
1969 Elan FHC S4 SE
- tonycharente
hi have just read your topic, i myself have just converted a s4 to road/race spec , and have made a adapter manifold for a single webber/ delorto carb ,i have used a webber45, with exceptional results , pulling 135 bhp @6500 on standard engine, the manifold is easy to fit can be fitted in about1hour, and the great thing you dont have to worry about carb balance , no need to have electric pump. if you would like a pic email me , [email protected] cheers del
800bhp escort cosworth, 1000bhp nissan skyline , rs200, ,rs 500 ,lotus europa twin cam ,lotus elan s4 rolling road , ecu remaps, powder coating ,like making things that work, do all my own engine work ,worked for cosworth,lotus , porsche, aston martin
- del@ace
