Fuel Injection,Engine Management
All things being equal I'll be there. The guys in the workshop at work are making an adapter so I can fit both water temp senders. so hopefully i'll also have the sensors sorted. I'll leave the dizzy intact so we can compare running
tim
tim
1972 +2S130
tdafforn - Coveted Fifth Gear
Some interesting comments on EFI. You can add me to the list of (future) 'converts'.. GSXR throttle bodies with a custom intake manifold in the pipeline; MS with wasted coil is the plan.
Anyone have any good/bad experiences/recommends for what material fuel lines would work well? Almost at the stage of starting to get the rolling chassis back together and that's the first thing I want to put in!
thanks
will
thanks
will
- ill_will
At the same stage as you regarding fuel lines..
My fuel system is going to have a low pressure prime pump filling a swirl pot and a high pressure pump priming the fuel rail with a return..
Was thinking of using braided hose for the exposed lines down the inside of the chassis.
tim
tim
1972 +2S130
Cleggie,
It's about time that you turned up at Swettenham; the CLOGs need to see if your alleged +2 now looks like a McLaren F1.
First Sunday in the month; 13:30.
Pete.
http://www.petetaylor.org.uk
Pete.
Will,Tim
You don't need braided lines if you keep them well away from the propshaft,you may need to drill feed holes through the end plates of the box centre section to keep it well away from said shaft...
If you guys are going to Donnington i would like to meet up & see the installation
Ian
Ian
- elansprint
I keep saying to people on this forum that I don't know - see you at Donnington. Every time I say or see this I shake my head in pathetic disbelief - without a specific plan it's a waste if 'breath'.
Lets somehow agree a plan - and I object to the suggestion that I hold a big banner above my head saying "I'm Brian Clarke".
Last year there was a suggestion that people should meet at the Club Lotus stand, or was it Lotus Drivers Club stand, I sort of forget, but remember I did not meet anyone.
I think maybe the easiest way to meet is to have each others mobile numbers and agree a time to meet at the CL or LDC stand. Better suggestions please.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
Brian we normally go saturday also i will be in the pink suit with a copy of the beano under my left arm
Ian
Ian
- elansprint
I'll make sure I'm back at the car at 12:00 for my butties and flask both Sat and Sun,see you there..
VWW965F
white plus2
VWW965F
white plus2
