What To Wash Carbs In?
Cleaning things....
If you can get access to an Ultrasonic cleaner (as used by Jewellery people) then this with the ammonia based cleaner is excellent.
I brought such a cleaner for ?100 and use it for loads of things where you don't want to remove the actual surface just the dirt etc.
The cleaner isn't just ammonia solution.. A mate got me some... but the ultra sonic is really good, it get's in the nooks and crannies where normal cleaning does not., even with mild detergent and warm water it is good.
I never tried it but I guess with an automotive degreaser/cleaner it may be even better!
- bvt
i use Dunk throw the carb in a large container for 24 hours and it comes out nice ed
Tim,
There was a thread on this last year (see archives). Redex is the weapon of choice. Leave your bits in it overnight and they will be gleaming in the morning!
Incidentally, if you take this the wrong way and put your personal "bits" in it, there is another type of Redex sold in the States which is for cows with sore udders- both ways you win!
Pete
Pete
Pete.
http://www.petetaylor.org.uk
Pete.
bag balm ?-----on your carbs?------must make them soft to the touch and easy to set up ed
I would stick with the special carburetor cleaners available at the auto parts store only. Carbies are made from rather highly reactive metals which are surface passivated with a variety of soft coatings which can be easily damaged. Once the corrosion process usually internally at the bottom of the float bowl gets well established then the carbie is toast.
-Keith
-Keith
- type26owner
