Lotus Elan
Front Left (I think) Brake Calliper Needed!
PostPost by: DreamsOfA26R » Thu Dec 07, 2023 4:16 pm
Hello all!
I’m now getting around to fixing the braking system and in the myriad of parts that came with the basket case of a project I picked up, I only have 3/4 brake callipers! I have both rears and what I Believe is the front right, but it appears I’m missing the front left. Attached are some pictures of what I do have.
Does anyone have a side input front left calliper I may purchase? I plan on having all the callipers rebuilt so I don’t need one in immaculate condition, just something that’s at least rebuildable.
9C63F5D3-3AD4-45D0-9FC7-F5B376F86850.jpeg and
CD3484B5-348A-4307-849D-BF91D09B189B.jpeg and
52D42EEC-7ABE-4C3C-BDDC-3B19FCF9F6DB.jpeg and
620CD1F5-FCC9-4E99-BE8E-FA9F732FD13A.jpeg and
1967 Lotus Ean Racer project
1967 Lotus Type 46 Europa
1983 Mazda RX7
1982 Mazda RX7 Racer
Vintage Lotuses and Mazda rotary engines!
DreamsOfA26R
First Gear
First Gear
PostPost by: StressCraxx » Thu Dec 07, 2023 5:47 pm
StressCraxx
PostPost by: tedtaylor » Thu Dec 07, 2023 11:18 pm
Girling brake calipers "14LF MK1" with pads, pins and spring plates, complete, rebuildable, for Lotus Elan and others
$150 matched pair
PM Sent
www.TaylorMadeClassicCars.com
http://taylormadeclassiccars.com/images/IMG_1469.JPG
plus shipping.
TED
tedtaylor
PostPost by: danielmo » Thu Dec 07, 2023 11:20 pm
That is a Type 12 Girling caliper. It is an earlier version used on the early cars. I am not sure if you can upgrade to the 14LF, but it might be easier as they are available new (as a repop).
Type 12
https://bpnorthwest.com/triumph/caliper ... 7-type-12/
14LF
https://bpnorthwest.com/triumph/caliper ... to-80-new/
danielmo
PostPost by: DreamsOfA26R » Tue Dec 12, 2023 4:35 am
Thanks to Ted for allowing me to buy his set of calipers! hopefully I can get the rebuilt soon and get them on the car!
1983 Mazda RX7
DreamsOfA26R
First Gear
First Gear
PostPost by: patrics » Sat Dec 16, 2023 4:34 pm
That is a type 14 caliper as it is a 3 bolt design, type 12 is a two bolt design and were removed from service because they were not considered strong enough.
Early S1 would have had type 12 but as they were returned in to the service exchange scheme they were replaced with Type 14 calipers.
patrics
PostPost by: tedtaylor » Fri Dec 22, 2023 4:11 pm
DreamsOfA26R wrote:Thanks to Ted for allowing me to buy his set of calipers! hopefully I can get the rebuilt soon and get them on the car!
I have one more set of front calipers if anyone is interested.
TED
TED
tedtaylor
PostPost by: tonyabacus » Sat Dec 23, 2023 4:48 pm
One quick way to know which side calipers fit is that the bleed valve usually sits at the top when the caliper is mounted, this enables air to mrise up to the bleed valve
tonyabacus
