Lotus Elan
1st 2nd synchro hub wanted
PostPost by: dgym » Sat Sep 18, 2021 11:41 pm
hi guys,
Im searching for an early type 1st 2nd synchro hub complete with inner and outer section and blocker bars if anyone has a one or a lead on one.
It's an early close ratio box.
part no 2820E7124A
cheers!
-Jim
36/6612
1967 S3 Coupe (left the factory in 66)
original rego PPC 8E
original owner B.M. Wetherill ..are you out there?
dgym
PostPost by: rgh0 » Sun Sep 19, 2021 1:52 am
I may have one for you. I will check in the garage today
PostPost by: SENC » Sun Sep 19, 2021 1:56 am
https://www.classicfordspares.co.uk/pro ... consul-mk1
This one is listed as for the early cortina - maybe worth checking - the E7124 matches part of the part number from the Elan parts number.
Henry
69 Elan S4
65 Seven S2
PostPost by: promotor » Sun Sep 19, 2021 6:41 am
There are two types of EARLY synchro units for 1st/2nd gear - the main difference being the size of the hole for the splines that match to the mainshaft. To help you get the correct one you should measure the hole or the size across the splines on the mainshaft.
However, a close ratio gearbox (2.5:1 1st gear) should have the earliest version which has the smaller hole with less splines. This gearbox is easily identified with the removable sleeved bush under 1st gear.
HTH
promotor
PostPost by: dgym » Sun Sep 19, 2021 7:00 am
promotor wrote:There are two types of EARLY synchro units for 1st/2nd gear - the main difference being the size of the hole for the splines that match to the mainshaft. To help you get the correct one you should measure the hole or the size across the splines on the mainshaft.
HTH
yes the sleeved bush version is definitely the one I have.
36/6612
dgym
