+2 Gauges/Instruments
The front end fire that destroyed everything in front of the bulkhead has also destroyed all the gauges, therefore I am in the market for everything!
They were as follows:
100mm 0-140mph Mechanical
10mm 0-8000rpm Tacho Electronic
50Mm Fuel inverted 270deg Electronic
50mm Amps inverted 270deg Electronic
50Mm Oil inverted 270deg Electronic
50Mm Temp inverted 270deg Electronic
I am not pedantic about them all being exactly correct, the most important ones at the moment are the Tacho and Speedo. If you have anything, please contact me!
Paul
Paul
It's not a rehearsal
- Gopherit
There is a speedo on ebay finishing at 22 -16 tonight, Thursday £69.50 no bids yet.
Eric in Burnley
1967 S3SE DHC
Eric in Burnley
1967 S3SE DHC
- ericbushby
Search for `Lotus Elan` then select `car parts`
Eric
Eric
- ericbushby
Hi Paul ,
I`ve got a plus 2 rev counter ( with an orange needle ... which I suppose you could repaint if incorrect ) , if it`s any help : ) ?
Cheers ,
Paul .
Cheers ,
Paul .
- Verve
Verve - tried to PM you but doesn't appear to be going. Will try again, interested in the Tacho.
paul
paul
- Gopherit
Hi Gopherit
If it appears to be stuck in your outbox, it is just that the recipient has not opened it yet. There is nothing you need to do.
Eric in Burnley
S3 DHC
Eric in Burnley
S3 DHC
- ericbushby
I may have a tacho, speedo, oil pressure, water temp, volts and fuel level available soon if you are interested.
- HCA
Hi Paul ,
I`ve just picked up your messages ... my rev` counter looks in good order ( not the usual rusty mess ) ... but you would have to get it checked/overhauled to make sure ... so just £50 + postage if you need it : )
Lockdown has at least made me sort out some more of my spare parts , which I will be listing shortly ... mainly for the "little" elan , with some cross over parts obviously ...
Cheers ,
Paul .
Cheers ,
Paul .
- Verve
