Lotus Elan
Lucas 23D4 breaker plate needed
PostPost by: 1963Turnerjohn » Sat May 30, 2020 12:33 am
I’m in need of a Lucas 23D4 breaker plate (this is a mechanical advance distributor)
Need to get my distributor set for a soon to be dyno test
Thank you
Canton Michigan USA
1963Turnerjohn
First Gear
First Gear
PostPost by: SENC » Sat May 30, 2020 4:16 am
Distributor Doctor has them. If you can't wait for overseas shipping or if they're temporarily closed I'm pretty certain I have a backup I'd sell for whatever it will cost me to replace it.
Henry
69 Elan S4
65 Seven S2
PostPost by: 1963Turnerjohn » Sat May 30, 2020 12:13 pm
I would like to buy the plate from you to get it quicker (postage is taking up to 2.5-3weeks from
Overseas to Michigan)
Thxs
Last edited by 1963Turnerjohn on Sat May 30, 2020 2:11 pm, edited 1 time in total.
1963Turnerjohn
First Gear
First Gear
PostPost by: SENC » Sat May 30, 2020 1:15 pm
Sent you an email.
Henry
69 Elan S4
65 Seven S2
PostPost by: 1963Turnerjohn » Sat May 30, 2020 6:09 pm
Many Thanks to SENC ! He already shipped out as well !
1963Turnerjohn
First Gear
First Gear
PostPost by: Elan45 » Sat May 30, 2020 9:30 pm
The original breaker plates had a tall pin for the breaker points to be assembled upon, but about 1974, they replaced the plate under the same part number with a version with a shorter post that was only suitable for use w/ the "quick fit" points set. Only an issue I think, if you are still using points ignition. Ref: old about 1/2" tall. new about 1/8" tall just from memory.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
Elan45
PostPost by: SENC » Sat May 30, 2020 11:40 pm
Happy to help, I know how it is when you get close and need one last bit!
Agree Roger. For any others in need, Distributor Doctor does carry the tall pin breaker plate. I had an extra plate with plans to premake a plate with points and condenser as a travel back-up for easy swapping - easier to replace a plate than trying to fit and gap new points in situ.
IMG_20200530_090615.jpg and
Henry
69 Elan S4
65 Seven S2
PostPost by: alan.barker » Fri Jun 26, 2020 10:09 am
I always remove Dissy to fit Points, very easy.
