Lotus Elan
inner door handle for S3
PostPost by: tricky_dickey » Thu Apr 30, 2020 1:39 pm
2 things - looking for a inner door handle mine has cracked the driver dog square -
please pm me [email protected]
also how do i change my password from what was sent to me
4QZ1X9A
tricky_dickey
New-tral
PostPost by: oldelanman » Thu Apr 30, 2020 2:34 pm
tricky_dickey wrote:2 things - looking for a inner door handle mine has cracked the driver dog square -
please pm me [email protected]" target="_blank" target="_blank" target="_blank
4QZ1X9A
You don't say where you are in the world but the interior door handle is available new from SJ Sportscars and possibly from the other Lotus suppliers in the UK
https://www.sjsportscars.com/parts-and- ... B6289Z.htm
To change your password try this...
Log In then click on the following...
FORUM PROFILE (Top RH of page) That opens up the User Control Panel
PROFILE
EDIT ACCOUNT SETTINGS There you can change your email address and/or password
S4 DHC
PostPost by: tricky_dickey » Thu Apr 30, 2020 3:45 pm
thanks will contact Steve and just figured out how to change my password
tricky_dickey
New-tral
PostPost by: tricky_dickey » Thu Apr 30, 2020 3:54 pm
I am located in Vancouver B.C. Canada
tricky_dickey
New-tral
PostPost by: Alasdair » Thu Apr 30, 2020 7:23 pm
If, you have a Super Safety S3 the door handles are different and, very rare!
Alasdair.
1953 David Brown Cropmaster
1954 S1 Land Rover
1962 Elite S2
1966 Lotus Cortina MK1
1968 Elan S3 SS Coupe
1968 Austin J40
1969 Elan S4 SE DHC
1972 Elan Sprint
Alasdair
PostPost by: Pastapesto » Thu Apr 30, 2020 8:31 pm
Alasdair is quite correct there, some of the later S3s had a different interior door handle.
The super safety type has the top part of the handle (at the pivot) hidden behind the door trim. It is a modified handle from something else, an Austin from the fifties if I remember correctly.......it has a couple of areas ground/machined away to make it fit.....I think I have the details "filed away" somewhere....let me know if this is the one and I will try to find them (the details!)..
Adam
Pastapesto
PostPost by: Elan45 » Tue May 05, 2020 11:19 am
I've had my SS since 1974 and I would like to have that information, just as a back-up.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
Elan45
PostPost by: tricky_dickey » Fri May 08, 2020 1:08 pm
Pastapesto wrote:Alasdair is quite correct there, some of the later S3s had a different interior door handle.
Adam
that would be great Adam - mine is different then all the others I'v had in the shop so it's been a bit of a struggle - i've temporarily made it work ( the back side where the pin goes through broke away on the drivers side so i made up a part for now and works for now
tricky_dickey
New-tral
