Lotus Elan
engine damage finally repaired
PostPost by: checkrail » Tue Feb 20, 2024 12:42 pm
Yes John, engines is in the car. if you stand facing the front the sump plug is on the left. The noise is continous for full rotation.
checkrail
PostPost by: smo17003 » Tue Feb 20, 2024 1:55 pm
Is the oil slinger correctly fitted? Here are a couple of topics with photos.
viewtopic.php?t=53535&p=390594
viewtopic.php?t=34537&p=234577
Also the dipstick and tube were previously mentioned, have you checked both?
1967 S3 FHC
1968 S4 FHC
smo17003
PostPost by: checkrail » Tue Feb 20, 2024 2:56 pm
The sump is off again,... you can now rotate the crank continously without any noise, the oil slinger is correctly fitted and the crank bolt torqued up
There is no sign of any damage to the sump
checkrail
PostPost by: types26/36 » Tue Feb 20, 2024 3:53 pm
I don’t know if its possible but could a big end catch on oil pick up/pipe or oil return pipe?
When the sump is on could it be moving the pick up to a point where it touches a big end?
Is the oil baffle plate secure and not catching the crank? I’ve had those baffle plates come lose before.
WELDED.jpg and
types26/36
PostPost by: checkrail » Tue Feb 20, 2024 7:21 pm
Once I had cleaned the oil from inside the sump I noticed the baffle plate although firmly welded had a shiney edge to it with a very small sharpish piece on top, I will file it smooth and see if there is any difference.
checkrail
PostPost by: checkrail » Thu Feb 22, 2024 4:46 pm
If anybody is still interested i filed the baffle, refitted the sump, rotated the crank by hand and the noise has gone
checkrail
PostPost by: pharriso » Thu Feb 22, 2024 4:50 pm
checkrail wrote:If anybody is still interested i filed the baffle, refitted the sump, rotated the crank by hand and the noise has gone
That baffle is not original.. What was it hitting? The Crankshaft?
Oh Wait, that was Brian's picture....
Can you post a picture of your sump?
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: types26/36 » Thu Feb 22, 2024 5:11 pm
pharriso wrote:[quote=That baffle is not original..
The baffle in my picture is original and correct for a 6 bolt crank, the 4 bolt crank has a different baffle.
types26/36
PostPost by: pharriso » Thu Feb 22, 2024 5:15 pm
Oh, didn't realize that.... Is that something Lotus added to the Standard Ford Sump?
p.s. Good to see you back Brian...
Phil Harrison
PostPost by: types26/36 » Thu Feb 22, 2024 5:22 pm
pharriso wrote:[
Don’t think it’s a Lotus modification, I think Ford added it as used on the MK2 Cortina as I recall.
types26/36
PostPost by: types26/36 » Thu Feb 22, 2024 6:29 pm
checkrail wrote:If anybody is still interested i filed the baffle, refitted the sump, rotated the crank by hand and the noise has goneJohn
hip hip hooray.jpg and
types26/36
PostPost by: smo17003 » Thu Feb 22, 2024 6:59 pm
Where was the damage to the baffle, right at the front beneath the timing chain?
1967 S3 FHC
1968 S4 FHC
smo17003
PostPost by: checkrail » Thu Feb 22, 2024 7:26 pm
My baffle is the same as Brian's, it had a shiney edge approx. in the middle with a small sharp bit sticking up, I nearly nicked my finger on it so filed it smooth,
I can only assume the big end was touching it, but how did it get like that?
checkrail
PostPost by: Bud English » Thu Feb 22, 2024 10:04 pm
Thin pan gasket?
Bud
1970 +2S Fed 0053N
Bud English
PostPost by: rgh0 » Thu Feb 22, 2024 10:47 pm
checkrail wrote:My baffle is the same as Brian's, it had a shiney edge approx. in the middle with a small sharp bit sticking up, I nearly nicked my finger on it so filed it smooth,
Something strange is going on here. The clearance of the centre baffle to the crank is substantial. The top is slightly below the raised rear section of the sump where it joins it so no way a small sharp bit on the baffle should hit the crank rods. Something appears to be non standard.
here is a photo of the standard 6 bolt sump and centre baffle
DSC_1318.JPG and
PreviousNext
Users browsing this forum: StephenT and 22 guests
