Lotus Elan
Timing chain
PostPost by: 2cams70 » Thu Nov 02, 2023 6:21 am
rgh0 wrote:I just posted the article as it provided some concise information around the advantages of solid roller chains. Plenty of other web sites provide similar information
When they are talking about solid rollers they are mostly talking about the Bush chains previously mentioned. These are low speed high load industrial chains. The timing chain used in an engine is high speed and the rollers need to rotate on their axis unlike a Bush chain.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
PostPost by: rgh0 » Thu Nov 02, 2023 7:02 am
I think you are confusing "Bush" chains that have no roller just a larger diamter pin connecting the links with "Roller" chains. Yes they are typically used in lower speed heavy duty industrial drives.
"Roller" chains use a roller around a smaller diameter pin and are typically used in higher speed and lighter duty drives such as industrial timing chains.
The discussion here is not about "Bush" versus "Roller" chains but about the use of solid pins and solid rollers versus split pins and split rollers on "Roller" chains.
PostPost by: 2cams70 » Thu Nov 02, 2023 7:22 am
rgh0 wrote:I think you are confusing "Bush" chains that have no roller just a larger diamter pin connecting the links with "Roller" chains. Yes they are typically used in lower speed heavy duty industrial drives.
No I'm not confused Rohan. Yes a Bush chain is where the roller does not rotate. The point I am making is that most if not all of that very reliable information (especially from Chinese/Taiwanese manufacturers) being sourced from the internet concerns split versus solid "rollers" on Bush chains not split versus solid rollers on roller chains. On a roller chain it's the pin the roller rolls around that takes the chain tension load and not the roller itself. The roller just rolls around as a bearing in other words.
PostPost by: rgh0 » Thu Nov 02, 2023 7:47 am
I will let others decide what to think and what chains to buy. I think we have exhausted this topic as is not uncommon when we try to discuss engineering details
PostPost by: 2cams70 » Thu Nov 02, 2023 8:18 am
Yes I agree it’s finished. For me at least I wouldn’t hesitate about putting a split roller chain in my engine provided it was of reputable manufacture.
PostPost by: alanr » Thu Nov 02, 2023 9:23 am
I am thankfully not in the market for a timing chain at the moment but I would not be happy building an engine currently to then fit a split roller timing chain.There is to my mind just too much at stake to risk when having spent substantial time, effort and money building an engine without further knowledge of these split roller chains.They may be ok, they may be not. Who knows at the current time?
Personally with the knowledge of this thread when I do need one I will be looking for an alternative brand of chain.
Do Renold still make a continuous timing chain suitable for a twincam I wonder and if so who can supply?
'71 +2 S130/ 5speed Type9.
PostPost by: HCA » Thu Nov 02, 2023 9:24 am
Reply from the IWIS distributer this morning - he is certainly intent in sending me down the split roller route :D
Yes I stock the bush chain, but really don’t think you need to go down that road, and if you do, you may have other issues with the size of it, (rubbing)
Perhaps best to get advice from QED as they are the experts with that engine.
Jeremy.
Hal Adams
Evora SR
Elan +2
HCA
PostPost by: alanr » Thu Nov 02, 2023 9:49 am
Hal,
I see Mountune describe their Twincam Timing chains as being a 'Heavy Duty' motorsport chain.
https://mountuneusa.com/products/heavy- ... s-twin-cam
Perhaps a conversation email with them on their chain could be an option for you?
Alan.
PostPost by: 2cams70 » Thu Nov 02, 2023 9:56 am
Let’s not get confused here. I too would prefer a chain that was not split link - i.e not an endless chain. Split rollers are a separate issue. You couldn’t use a Bush chain in a twin cam. Disaster! way too much internal friction. Twin Cam steam engine maybe but not a Lotus Twin Cam.
PostPost by: alanr » Thu Nov 02, 2023 10:15 am
i don't think anyone is confused at all.
All the conversation has been about split roller and not about split link which is a different subject altogether.
Alan.
PostPost by: HCA » Thu Nov 02, 2023 10:50 am
And here is the reply from Cross and Morse...
Good morning Hal,
I hope this email finds you well,
I'm afraid we have stopped making these chains some time ago.
Sorry we cannot be of much help.
Kind Regards,
Jonathan Vargas
Export Sales
Cross+Morse
Tel: +44 (0)121 360 0155
Hal Adams
Evora SR
Elan +2
HCA
PostPost by: promotor » Thu Nov 02, 2023 5:37 pm
HCA wrote:And here is the reply from Cross and Morse...
Good morning Hal,
Kind Regards,
Jonathan Vargas
Export Sales
Cross+Morse
I'm surprised at that - I think I bought one last year. Be interesting to know why they stopped.
Are they referring to the 122 link chain or the 120 link, or both?
promotor
PostPost by: HCA » Thu Nov 02, 2023 5:49 pm
I only asked for a 122 link..,
Hal Adams
Evora SR
Elan +2
HCA
PostPost by: rgh0 » Fri Nov 03, 2023 12:19 am
Just for information this is the page from the IWIS catalog.of the relevant chain specification JWIS G67, ISO British Standard Chain 06 B-1. This chain has solid rollers according to the catalogue. I can find no reference to a split roller chain to this dimensional specification in the catalogue
JWIS ISO 606 British standard chain.pdf
(331.19 KiB) Downloaded 113 times
The Reynold catalogue shows they have solid roller chains to the same specification.
PostPost by: 2cams70 » Fri Nov 03, 2023 1:49 am
There’s no mention in the catalogue whether they are solid rollers or not. You’d have to ask. Chances are if you bought such a chain you’d have to join it with a split link. Given the choice between a split link and a split roller I know which I’d prefer.
PreviousNext
