Lotus Elan +2 engine removal
Hello,
I'm in the middle of removing the engine from my +2 rolling chassis. I've managed to split the transmission from the engine a distance of 1 inch all the way round. I'm simply unable to work the engine free of the gearbox despite rocking the engine from side to side. I've even tried a couple of wedges without success. The chassis is supported on axle stands and I don't want to knock the chassis off while I'm rocking the engine. I've read the threads in the Forum but I need some advise at this point.
- mcole01
Have you lifted Engine enough with top of Bellhousing touching the Body.
The front of the Sump can touch the Chassis cross member.
There is an Earth Braid from Oil Pump.
- alan.barker
What is your arrangement for supporting the gearbox at this point? You may need a slight lift under the bell housing to free things up.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
Thanks for you replies.
Yes, I've removed the earth strap and I have the gearbox supported on a trolley jack. I've tried to keep the gearbox as parallel to the engine as possible to prevent binding. I can push the engine to the left and right but I lack the ability to pull the engine forward away from the gearbox other than by using wedges between the gearbox and engine.
- mcole01
For the Clutch what Bolt/Screw are you talking about i 'm lost.
You have the top bolt for the Starter next to a Bell Housing Bolt.
- alan.barker
Hi Mike,
Good luck as you advance.
Sounds like you're having fun.
- alan.barker
mcole01 wrote:Alan,
I misspoke. I was referring to the bolt that retains the steel plate between the back of the engine and the bell housing. The bolt is about an inch above the clutch slave cylinder that's mounted on the exhaust side of the bell housing.
Been there, done that !
68 Elan +2, 70 Elan +2s
Foxie - Coveted Fifth Gear
Users browsing this forum: snowyelan and 23 guests
