Removing timing front cover
As the cover wasn't coming off no matter how much leverage I did, I then tried a slide hammer fixed on the pulley flange, again no movement in waterpump it just started to move the pulley flange. So then I decided to carry on and remove the flange from the shaft. I removed the retaining clip, then with help, had levers under each side of cover and with a mallet knocked the shaft down, this is then obviously what caused the bearing assy to come out of the cover. Now I have everything off I can see there is no way the pump would have come out of the back plate conventionally, its so corroded up. Had to press out on fly press.
friedy - Second Gear
The aluminium 'doughnut' with the two O-rings in the waterpump should never have any sealant goo on it. the proper procedure would be just to oil the O-rings (or maybe use thin grease) before fitting it into the front cover. The rubber O-ring does the sealing!
I think I'd be inclined to use some copper grease there, though I would check to see about any copper-aluminium reaction first. I've only used oil or thin grease on previous replacement of water-pumps and I've done many.
The same advice applies during fitting of the cartridge water-pumps in the 'Burton' or other front conversions.
My normal way of getting the front cover off was to use a two long strips of wood with rectangular cross-section (says 2"x1" but may need a smaller one to fit in). slide them down inside the timing case from the top, then twist them both so that they apply a fairly even outward force to the front cover.
Users browsing this forum: alan.barker and 27 guests
