Replacement cooling fan
PostPosted: Tue Jul 20, 2021 1:06 pm
by englishmaninwales
1966 S3 with the wide Triumph / Stanpart radiator.
Following a blade letting go on my massive, but highly effective, non standard set up stolen from the 1970 Fiat range of saloons, with the blade damaging the radiator ( getting repaired) in the process, I’m looking for a replacement fan, I saw this:
https://paulmattysportscars.co.uk/produ ... -radiator/
Anybody tried it and is it up to the job? Do I need two? I’m told by PMSC parts it has reversible polarity, so push or pull?
The car is in regular daily use throughout the UK summer.
Thanks for any advice.
Malcolm
Re: Replacement cooling fan
PostPosted: Tue Jul 20, 2021 2:05 pm
by USA64
The fan blades have dimples? I think on a golf ball they add lift, but why on a fan blade? :?
PostPosted: Tue Jul 20, 2021 3:50 pm
by lotusfan
Hi Malcolm
I have a Coolex aluminium rad on my car of the normal Sprint size and a 10 inch version of the fan that PM sells. Cooling is not a problem. My fan came from SVC and I notice that their prices are higher than PM.
If I had the wider rad like you have I would probably go for 2 fans just because you can but 1 fan works for me.
I would also configure them as pullers given a choice because it is better for the airflow.
Ref the comment on the dimples on the fan blades. My understanding is that golf balls have dimples to reduce the drag and allow them to go further. Dimples on a fan blade will presumably reduce the drag and allow the fan to produce more airflow.
PostPosted: Tue Jul 20, 2021 3:59 pm
by HCA
I see a long post ahead on what is best - push or pull :lol:
PostPosted: Tue Jul 20, 2021 5:06 pm
by h20hamelan
don't most have push one side and pull the other
debate over?
PostPosted: Tue Jul 20, 2021 6:18 pm
by TBG
This works for me.................Two big pushers - happy at idle in 35c heat traffic jams. D
DSCN2684.JPG and
PostPosted: Thu Jul 22, 2021 8:25 am
Thanks for the advice.
PostPosted: Thu Jul 22, 2021 6:11 pm
by Spyder fan
TBG wrote:This works for me.................Two big pushers - happy at idle in 35c heat traffic jams. D
Helicopter rotors?
PostPosted: Thu Jul 22, 2021 9:24 pm
by TBG
This one perhaps? D
140 degrees bank.jpg and
PostPosted: Thu Jul 22, 2021 9:47 pm
by elanfan1
Oh God here we go!
PostPosted: Thu Jul 22, 2021 11:39 pm
TBG, is that a Coolexpert rad?
PostPosted: Fri Jul 23, 2021 8:02 am
by TBG
GJZ - yes it is one with Revotec fans and mounting bracket. All quite beautifully made. D
Coming to get you Elanfan...............................
jsf_Wx5_Rocketing - Copy.jpg and
PostPosted: Fri Jul 23, 2021 8:20 am
by Spyder fan
TBG wrote:GJZ - yes it is one with Revotec fans and mounting bracket. All quite beautifully made. D
The attachment jsf_Wx5_Rocketing - Copy.jpg is no longer available
Bet that made your bum warm David :mrgreen:
The coolexpert radiators are very good, I have a Tony Thompson in mine, but only because I didn't know about the coolexpert ones at the time.
This is it converted for a zetec
Copy of DSC00912.JPG and
PostPosted: Fri Jul 23, 2021 9:18 am
by elanfan1
I’m certain it’s not within navy regulations to light your own farts during a flight. You must be a very windy fellow!
PostPosted: Sat Jul 24, 2021 2:08 pm
by The Veg
How dimples work:
https://www.scientificamerican.com/arti ... n-golf-ba/
This, however mya differ somewhat for the fan since the motion of the blade and the airflow around it is different to that of a back-spinning ball.
