Lotus Elan
Timing chain case and water pump fittin
PostPost by: bloodknock » Mon May 03, 2021 9:41 am
Which is the best front cover / timing chain case and water pump fitting modification to use?
PostPost by: billwill » Mon May 03, 2021 10:54 am
Different front covers usually (if not always) require changing the back cover to match.
PostPost by: billwill » Mon May 03, 2021 10:56 am
This has been discussed many times, try browsing through this lot.:
https://www.google.com/search?q=modular ... usElan.net
PostPost by: TBG » Mon May 03, 2021 1:40 pm
At the risk of becoming even more boring this modification almost totally stops water pump failures. Big caveat here - if you don't use it it will fail when you do!! D
Alternator pulley.jpg and
TBG
PostPost by: englishmaninwales » Tue May 04, 2021 5:51 pm
Bob,
I’ve sent you a PM.
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
