water pump removal
• Page 3 of 3 • 1, 2, 3
2cams70 wrote:Foxie wrote:As The Good Soldier Svejk would say, I humbly beg to report that I have fitted two cartridge water pumps, and had absolutely no problems.
Also removed and refitted them for engine rebuilds. No problems.
Aaahem - you should count yourself lucky in that case!!
viewtopic.php?f=39&t=43910&start=
Yes, I've had a look at that.
You certainly seem to have been in the wars !
68 Elan +2, 70 Elan +2s
Foxie - Coveted Fifth Gear
To seperate i would drill holes into the Cast Impellor next to the Pump Shaft. Then split Impellor. Remove from front the Special Wire Clip. Use small puller to pull Flange off Shaft.
Warm up and it should all dismantle.
- alan.barker
vstibbard wrote:Foxie, which make of removable pump did you use?
V
The first one was for my tall block project , from QED in 2003.
The second was from Burton in April 2012, price £96.69, and the third (for a new engine) also from Burton in Jan 2016, still at £96.69
Astonished just now to see the price was still the same after 4 years !
Just a reminder: the timing case will normally require some machining to get it exactly level with the block deck
Users browsing this forum: Blockhead and 32 guests
