cometic cam cover gasket
hello again, i think that i intend to use the cometic cam cover gasket on my twincam engines and not the cork standard type. could anyone give a view as to the type of gasket product i should use on each side of this type of gasket to avoid any oil leaks at all. thank you.
- J J DIKKE
This has been covered before but i know this forums search engine isn't the easiest to find what your looking for.
So, the Cometic cam cover gasket is only usable in my opinion if you have first checked the head and cam cover is flat!! The cover does tend to warp and if there is any warpage you will really struggle to get a Cometic gasket to seal.
Thats why the cork gasket is good as it gives you a much bigger tolerance to warpage.
As for gasket sealer it depends how well you want it stuck....... i use a smear of permatex aviation sealer which does the job fine but i know a number of people that use permatex ultra grey, but it has been known to cause future cam cover removal issues and is a bit ott in my opinion.. Again it depends how flat your two mating surfaces are.
Grizzly - Coveted Fifth Gear
hello again, thanks for the info and opinions thus far these are good. i have a brand new 4k head on my newly rebuilt engine and i have had 3 of my cam covers skimmed to flat. i had considered using permatex aviation, form a gasket liquid on both sides of the cam cover gasket, either cometic or standard cork. i simply wish to be as sure as i am able that this expensive engine will not leak oil, at least from the area we are discussing at this point. i also have additional ideas in respect of the rubber/steel washers on the cam cover studs if any one may be interested. thank you, dennis.
- J J DIKKE
patrics wrote: but my experience on an old head and cam cover it was useless - don't waste your time - or your oil for that matter .
+1 on my +2 on this. Leaked appallingly at the 'D' plugs. Cometic thermostat housing gasket - brilliant and reusable.
Jeremy
JJDraper - Coveted Fifth Gear
JJ Dickk: Have you read through this thread:
viewtopic.php?f=39&t=45590
I ordered a sheet of the nitrile rubber but have not used it yet.
'65 S2 4844
- Davidb
I wrap the D plugs w/ the plumber's teflon pipe thread sealing tape. Once around, maybe 1-1/2 times is all you need. The little bump on the D plug will push out through the tape and keep the plug from loosing position latterly. Don't wrap it too tightly. You want a small amount of build-up.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
Elan45 wrote:I wrap the D plugs w/ the plumber's teflon pipe thread sealing tape. Once around, maybe 1-1/2 times is all you need. The little bump on the D plug will push out through the tape and keep the plug from loosing position latterly. Don't wrap it too tightly. You want a small amount of build-up.
If I understand Jeremy correctly and I think I experienced the same issue, the problem is not the D plugs leaking on their circular face, but on the top surface. The Cometic gasket has no give in it, so if the top of the D plug is proud of the head face the Cometic gasket acts like a bridge and leaves an airspace underneath, that's where the leaks come from.
Mazzini - Coveted Fifth Gear
