Lotus Elan
Oilite pilot bush needed
PostPost by: 1963Turnerjohn » Sun Jan 12, 2020 12:49 am
I?m in need of an ?Oilite? pilot bushing for a 4 bolt crank
ID = .59 inch
OD = 1.58 inch
I checked Dave Bean. They have only a brass - non oilite Bush or roller
Thxs
1963Turnerjohn
First Gear
First Gear
PostPost by: Certified Lotus » Sun Jan 12, 2020 3:49 am
Try RD Enterprises. They should have them.
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
Certified Lotus
PostPost by: avro » Sun Jan 12, 2020 9:26 am
Hello John
There are two sizes of first motion shaft (spigot shaft) depending on the gearbox being used. The very early close ratio gearbox had a larger diameter end to the shaft. Your 4 bolt crankshaft being in a slightly later car with the semi close ratio gearbox uses the same internal diameter bearing (.590?) as the 6 bolt crank. If you still have your old bearing but it?s just worn then it can be machined out and the roller bearing that is used in the 6 bolt crank can be pressed into place. If you don?t have your original bearing then a steel sleeve can be machined of the same OD with the roller bearing fitted.
Nick
avro
PostPost by: englishmaninwales » Sun Jan 12, 2020 6:17 pm
John,
You have a PM.
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
PostPost by: 1963Turnerjohn » Mon Jan 13, 2020 10:22 pm
Located a couple NOS bushes so all set - thank you guys for the feedback
1963Turnerjohn
First Gear
First Gear
