Valve Shim interchange
I am adjusting the valve on a freshly rebuilt engine. After break in and run of around 1,000 miles I torqued the head bolts and checked the valves. Bean recommends .009" for the exhaust and .008" for the intake on a .420 cam.
#4 intake was at .016" so I decided to adjust the valves. The top hat shim is what I found.
I believe the spring retainers and keepers are typical ... Is there any reason I couldn't use a standard shim to replace this one?
Greg
Greg
'67 s3 SS
'72 +2 S130
'72 +2 S130
- Greg Foster
Greg,
I use the top hat and disc shims interchangeably. Why not?
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
Greg Foster wrote:Just read the post
Greg
Yes. Whether you can or can't depends on what retainer design you have
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
I will check it out tomorrow to see if the puck shim will work.
Greg
Greg
'67 s3 SS
'72 +2 S130
'72 +2 S130
- Greg Foster
