Trigger for a whole heap of work...
It is possible to purchase gaskets of different thicknesses to compensate for varying deck heights. See link:
https://www.lotusmarques.com/info/techn ... sket-guide
The best and cheapest bet is to buy your own gasket material (you then have the choice of the best quality material) and cut them yourself. It's relatively easy to do with an Exacto knife and some hollow punches. The best cork gasket material to use is the sandwich type. This has an aluminium foil reinforcement sandwiched between two thin layers of cork. The aluminium reinforcement helps stops the cork from extruding under pressure. The timing chest gasket that came in the kit I bought from QED was the cork sandwich type. A lot of them are fully cork without the reinforcement.
You can use some of this stuff too to help stop the gasket extruding:
https://www.henkel-adhesives.com/us/en/ ... alant.html
I must say it's really ballsy of you to pull a Lotus engine out by the side of the road!! Definitely some pictures there for the grandchildren if you have them. A good incentive to get the job done in a hurry no doubt. Be careful of the local council though. Mind you it's an excellent excuse for getting out of a parking fine. Ummm sir - but my car has no engine!!
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Short block has been taken to my engine man and after a good inspection of the bores, he is confident that they are still good, just glazed and no wear lip. If the pistons are in the same state, they can be re-used with new rings and a hone. Need to check the ring land clearances though. This bodes well for the crank, which may only need a polish and new shells. More news when the block is torn down and inspected in more detail.
He confirmed that the block has been decked at some point, meaning there was no step between the alloy water pump case and the block. No wonder the cork gasket just squished allowing oil to p*ss out. He intends to machine the pump case to give an appropriate step - no more oil leaks, hooray!
With regard to the water pump itself, we need to check what the arrangement is and may even re-use the ceramic washers if they are in good condition. Apparently this is a problem area with pattern parts not being up to the job..
On another note, the clutch is close to the limit, so another bullet dodged, re having to take the engine out. This has done around 45k miles, fitted by Mattys. I note the friction material, looked at edge on is wavey, but worn flat - seems odd.
The work keeps piling up, but should be within budget.
Jeremy
Jeremy
JJDraper - Coveted Fifth Gear
The disk between the friction faces has its sections slightly offset to give some spring compliance so that the clutch takes up more smoothly producing the wave pattern you see on the edge. Under the clamping pressure this flattens out.
Be careful in just assuming you need to machine the front cover. Measure twice cut once. With these engines you can't just assume the deck and head faces have been machined perfectly horizontally and that the front of the block is perfectly at right angles with the deck face. My engine was exactly the same but when I did a trial build by plonking the head back on with a gasket and then torqueing it up I found that lo and behold the clearance for the cork gasket was in fact perfectly OK. I reckon it's always worth buying two cylinder head gaskets of the same type as you intend using. Accept the fact that you'll use one for the trial build only and the other for the final build.
- 2cams70
Thanks for the heads-up re the step between the timing chest and the block. Mine has no step at all - completely flat across the block & timing chest. The cork gasket was squished to smithereens (see earlier pics), so an appropriate reduction in the height of the timing chest would be useful to reduce oil leaks. I trust the advice I have received for this.
The workshop have had the opportunity to tear down the block and examine all components for wear. The news is good so far. Pistons and ring lands have next to no wear and even the rings show little wear. His advice is to re-use the pistons, pins and rings, with a bore hone. I was somewhat surprised by this advice, but he knows his stuff. Similar story with mains and big end shells. OK, but will be replaced. Crank is on +20thou and big ends at +30, but all bearing surfaces good to go again.
Negligible corrosion of the alloy covers and they came apart and away from the block easily. Must have been all the oil leaks.
All in all good news and extreme surprise at the low wear levels internally. He is used to seeing Twin Cams knackered at 10k miles and pigs to take apart, so this one has been the exception.
I will deal with the head, as I have experience of working with these and replace the sprockets and chain, as they show some pitting and are a little 'sharp'.
The secret, IMHO is good synthetic oil, with regular changes; appropriate grade for summer/winter and, possibly most importantly, letting the engine warm up properly before thrashing it.
Jeremy
Jeremy
I agree with the synthetic oil but I?ve been told it prevents a 'new' engine from bedding in, so start with mineral oil. Anyone any experience on this?
Ref. machining a step. Is this usual? Mine is completely flat and I?d assumed they all were?
Elan +2
Elise mk 1
Elise mk 1
- Donels
Donels wrote:Ref. machining a step. Is this usual? Mine is completely flat and I?d assumed they all were?
There is usually only a small step and it is mentioned in the w/shop manual.
Personally I don't think it makes any difference what oil is used in a Twin Cam engine wear wise, so long as it is suitable for same and is CHANGED REGULARLY. That is key.
Last year I rebuilt an engine from one of my cars that had covered 40k miles since its last rebuild. The only reason I rebuilt it was because it was leaking to much oil and I was fed up moping up! Over those 40k miles, I had shuved everything and anything into that motor, including oil that I inherited from a dear friend, that was at least 30 years old, but obviously new All the oil used in the engine over that period was mineral oil.
So, on rebuild, what was required? Just the journals had a light polish and new, same size as removed bearings. Bores were not touched, not even deglazed, as there was no discernable wear. Pistons and rings were just ultrasonicly cleaned, kept in exactly the same positions as removed, and replaced.
Change your engine oil frequently gentlemen, whatever you choose to use. You know it makes sense.
Leslie
Leslie
- 512BB
types26/36 wrote:There is usually only a small step and it is mentioned in the w/shop manual.
They are talking about the steps between backplate and front cover and between backplate and cylinder block sump mounting face. They don't mention or include the step between the backplate and the cylinder block deck face which is the one which affects the cork gasket compression. If you do a trial build with cylinder head gasket in place and determine the actual clearance there and hence the amount of compression of the cork gasket you can't go wrong.
- 2cams70
A little update. The engine has been fully disassembled and inspected, with as close to no wear as a feeler gauge can discern. We therefore intend to change as few parts as needed - bearing shells, just because we are in there; all cam/crank sprockets and chain, gaskets and the fiercely expensive +5thou thrust washers.
I know the adage of "freshly rebuilt engine sir (with all the old parts)" , but having inspected the parts myself, I can understand why.
Judge for yourself from the pics, and bear in mind this engine has done well over 100k miles in my ownership. Bottom end was rebuilt (well) by the PO, apart from the lack of a step between the block and the water pump housing and had covered some mileage before I got it. The lack of the step was due to not positioning the cover correctly before tightening it, as was pointed out by Type26 - a common problem apparently. So no machining required.
I am staggered by the lack of wear on the pistons. Only No.4 shows the slightest wear at the base of the skirt. Everything else is almost as new.. ring gaps, lands etc. Bearing shells show very slight wear and the crank journals none. These parts have not been cleaned, apart from a wipe over with workshop tissue.
Change that oil regularly.
Jeremy
Jeremy
JJDraper wrote:The lack of the step was due to not positioning the cover correctly before tightening it, as was pointed out by Type26 - a common problem apparently.
Best to use a centralisation tool on the crankshaft to align the front cover. It's easy to have one made up. If you overtighten the three bolts that screw into the top of the cover this can pull the cover out of alignment and toward the head. It really is a bad design. It really needs dowel pins to keep things in correct alignment during service.
- 2cams70
After an eternity, mostly caused by work commitments, the engine is now back in the car after 6 months. What a palaver, not helped by freezing weather and damp.... My first time putting an engine back in.
The engine hoist is only a 1 tonne unit so only just has the reach to get the engine in, and then only from the side, with the offside wheel taken off. First problem was to get the engine in, with the gearbox in place - jacked up the gearbox as high as it would go, then ease the engine into position. With much jiggling (of the engine) and swearing (by me), the engine just cleared the chassis member and dropped in. Jacked up a rear wheel & put it in gear to rotate the gearbox input shaft, while a willing helper jiggled the engine a bit more to fully engage the shaft and the engine. Then do up the engine/gearbox bolts and start putting on the engine mounts. 90% of our time was getting the engine fully in the engine bay and lined up. Once that was done the rest was plain sailing - put on engine mounts - oh dear - close examination showed the intake side mounting heavily sagged and cracks starting. It would have been so much easier to do the mounts with the engine out (spyder mounts) .
Anyway, mounts done (had a pair in stock); head back on; valves timed and starter motor back on. Enough for the moment, as a heavy frost then rain is making the task rather unpleasant....
Recommendations:-
check everything that could be knackered and replaced easily with the engine out & do it!
Get a 2 tonne hoist with a longer reach.
Proper mechanics gloves are great (if expensive).
Jeremy
PS I have included pictures of the engine mounts for comparison. The exhaust side has a natty cosy, and was nowhere nearly as sagged as the other side, so perhaps it does some good.
Recommendations:-
Jeremy
