COMETIC seems to work --- B U T now i have to confess:
PostPosted: Tue Jun 11, 2019 5:07 pm
by el-saturn
.........................last time i put the engine together i had to turn the waterpump flansh around - i used a puller and heated the flansh B U T in the process maybe some of the RTV / wellseal sealants resp. the seals (around waterpump) could have broken. this would allow cooling water to enter the timing case. ----------------------------- free cream sandy
P L E A S E add your comments
Re: COMETIC seems to work --- B U T now i have to confe
PostPosted: Tue Jun 11, 2019 8:24 pm
Sandy, for F***cks sake, just create 1 thread & update it, we don't need 5 or 6 different threads on the same topic!
I for one will not be reading them all.... :roll:
PostPosted: Tue Jun 11, 2019 8:52 pm
by el-saturn
as this was my last post, COMETIC D O E S N ' T work - same cylinders wet. everybody told me to stick with an ajusa - will do. my dealer hopefully has a 85mm version in stock. i controlled all surfaces: the block: can't even see light. and head (between cylinders) i can slip 0,0015" thru (0,0361) Sandy ---- i dont really this its the waterpump, becaause the cylinders wouldnt be full of water
PostPosted: Tue Jun 11, 2019 10:18 pm
by mark030358
Check that the bolt holes (threads) in the block are clear and that the head bolts are not bottoming out. What can happen is you reach the required torque but the bolts have actually not gone down far enough to compress the gasket fully. Nothing wrong with Adjusa gaskets by the way.
Or that the bolts have not elongated.
PostPosted: Tue Jun 11, 2019 11:52 pm
Check old gasket thickness for equal compression, use engineer?s blue or the like and scrape both head and block for flatness.
PostPosted: Wed Jun 12, 2019 2:41 am
by Elan45
I'd certainly be looking at the cylinder bores in the block, at least the ones which are getting wet.
Roger
PostPosted: Wed Jun 12, 2019 10:42 am
by el-saturn
head allows the 0.0015 gauge thru, but only between the cylinders (1 inch length x 3) - otherwise flat - the block is probably within 0.0001mm (you can't see light) sandy
PostPosted: Wed Jun 12, 2019 2:01 pm
Sandy, you seem determined to build an unreliable engine!! Clearly you enjoy the adrenaline rush of not knowing if the next key turn will wreck your engine
PostPosted: Wed Jun 12, 2019 4:50 pm
by el-saturn
will get a new ajusa next tuesday - you know the saying: NO GUTS NO GLORY!! you shouldv'e seen some of the projects i was involved in: in motorsport there's loads of very crazy people and even crazier drivers and lots of underdimensioned parts (ronnie peterson, jochen rindt) !! sandy
PostPosted: Wed Jun 12, 2019 9:34 pm
by JJDraper
Hi Sandy, it may be worth having a look at my post on head gasket sizes - 84mm vs 85mm. What size are your pistons? At +60 on mine - I concluded the 85mm gasket is too big.
Just reporting my experience with them.
Jeremy
PS I have had enough of the creamy brown stuff....
PostPosted: Wed Jun 12, 2019 9:40 pm
by JJDraper
PS Sandy, at least your workshop has a roof and no passing spectators willing to offer advice! :)
Jeremy
PostPosted: Thu Jun 13, 2019 5:24 am
by el-saturn
jeremy - you really are exposed to everything, it even rains sometimes in england! ---- reminds me of my 1st legal car i had (alfa giula super 1600), having the same type of garage / = parking lot. the goood thing is: the swiss are car-unfriendly, so you don't get any stupid, unwanted advice!! Sandy ps try changing oil: i did, they say nothing, but brits may however ask u if u find this "sustainable"!?!?! your lovely car deserves a nicer home though imo
