COMETIC seems to work --- B U T now i have to confess:
.........................last time i put the engine together i had to turn the waterpump flansh around - i used a puller and heated the flansh B U T in the process maybe some of the RTV / wellseal sealants resp. the seals (around waterpump) could have broken. this would allow cooling water to enter the timing case. ----------------------------- free cream sandy
P L E A S E add your comments
- el-saturn
as this was my last post, COMETIC D O E S N ' T work - same cylinders wet. everybody told me to stick with an ajusa - will do. my dealer hopefully has a 85mm version in stock. i controlled all surfaces: the block: can't even see light. and head (between cylinders) i can slip 0,0015" thru (0,0361) Sandy ---- i dont really this its the waterpump, becaause the cylinders wouldnt be full of water
- el-saturn
Check that the bolt holes (threads) in the block are clear and that the head bolts are not bottoming out. What can happen is you reach the required torque but the bolts have actually not gone down far enough to compress the gasket fully. Nothing wrong with Adjusa gaskets by the way.
Or that the bolts have not elongated.
I'd certainly be looking at the cylinder bores in the block, at least the ones which are getting wet.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
will get a new ajusa next tuesday - you know the saying: NO GUTS NO GLORY!! you shouldv'e seen some of the projects i was involved in: in motorsport there's loads of very crazy people and even crazier drivers and lots of underdimensioned parts (ronnie peterson, jochen rindt) !! sandy
- el-saturn
Hi Sandy, it may be worth having a look at my post on head gasket sizes - 84mm vs 85mm. What size are your pistons? At +60 on mine - I concluded the 85mm gasket is too big.
Just reporting my experience with them.
Jeremy
PS I have had enough of the creamy brown stuff....
Jeremy
JJDraper - Coveted Fifth Gear
jeremy - you really are exposed to everything, it even rains sometimes in england! ---- reminds me of my 1st legal car i had (alfa giula super 1600), having the same type of garage / = parking lot. the goood thing is: the swiss are car-unfriendly, so you don't get any stupid, unwanted advice!! Sandy ps try changing oil: i did, they say nothing, but brits may however ask u if u find this "sustainable"!?!?! your lovely car deserves a nicer home though imo
- el-saturn
