Compression ratio
Having identified from the piston code that my engine is bored to +.040 I have now calculated the compression ratio. This would appear to be 10.56:1 assuming the combustion chamber volume is standard for a S130. I don't have the head at the moment so cannot measure it.
10.56:1 seems a bit high to me for a standard road engine and todays unleaded fuel. Should I be fitting a thicker gasket to get the CR down a bit?
Anyone got any experience.
Dave
Dave
Elan +2
Elise mk 1
Elise mk 1
- Donels
Hello Dave
10.56 is a little on the high side. Dare l suggest that your calculations may not have taken into account that the piston on a standard unsurfaced block sits approximately .025? down the bore at TDC and the Powermax pistons that you are using have the larger valve pockets. I am of course assuming that your block has not been refaced.
Nick
Nick
- avro
You are making a lot of assumptions on an old engine. Best to CC the combustion chambers as it's quite unlikely they will be standard.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
With a short duration standard sprint road cam 10.5 to 1 is Ok on 98 Octane unleaded and you may get away with 95 Octane. Potentially you could push it a little higher on 98 Octane. If you want to get fancy with knock sensors controlling the ignition you can go to around 11 to 1 and maybe more.
Users browsing this forum: jdouglas300 and 29 guests
