Engine running troubles
Posted: Fri May 03, 2019 4:32 pm
My Elan +2 has been running poorly for a while, and I'd got into a spiral of not using it much because it didn't run quite right, and therefore it probably got worse because it hadn't run much. I'm determined to sort it out before the weather turns nicer (!?).
It has been blowing a lot of smoke and the plugs were getting clogged up quite fast, so initially assumed it was probably running rich and needed the carbs retuned. However on trying to do that, I've found it constantly hunting with revs roaming up and down whether I am tweaking the tuning or not.
Quick bit of background, it is a mildly modified engine - has a ported head with CPL2 cams from Paul Fisher a few years back, is set up at compression ratio of 10.1:1 and the carburettors were jetted and tuned up on a rolling road at Sanspeed a few years back. We got about 115bhp out of it.
Once my tuning attempts were going nowhere I did a compression check - all pistons are 200-205 psi, so look healthy.
I therefore wondered if oil was getting in through the valve guides - they shouldn't be as the head hasn't done many miles - but removed the carbs to have a visual check of the inlet valves at least. I know twincams are expected to burn some oil down the valve guides, but was a bit surprised to be able to actually see a drip of oil at the bottom of some of the valve guides. There are small but stubborn burnt carbon patches on the trumpet part of the valve.
I've attached pictures and hoping those who have seen more of these engines can advise whether this looks excessive or not.
Assuming it is OK, I thinking my next step may be to refit the carbs - ensuring there are no leaks from the rubber ring/plate couplings, which I guess could have been another cause of the hunting. I'll tune it as best I can and then give it a good 50 mile a-road drive to see if just giving it a blast will clear it out a bit - I'm aware it has spent too long in slow traffic on the last few occasions it has been out, or even just being started to drive it in and out of the garage. Then I'll see if I can give the tuning another go.
Any other ideas of stuff to check out would be appreciated though.
Martyn
Martyn
