Sealant on Two or Four Sides of Curved Cork End Gaskets
Posted: Fri Mar 08, 2019 4:22 am
Forgive me if this has been covered, but I couldn't find the answer.
I'm about to seal up my oil pan. I see the dozens of posts about RTV versus Aviation Form-A-Gasket, and the advice to stick the long pan gaskets to the block first and THEN mount the pan. I also see advice to use sealant on both sides of the curved cork end gaskets, but my question is... I assume that "both sides" means the bottom side against the pan and the top side that faces down inside the groove, but what about the two other sides of the curved cork end gaskets that face inward and outward? Some of the posts say that the sealant helps the gasket slide into the groove. That sounds like the sides of the gasket to me. Should the bottom surface against the pan get a sightly thicker layer and the other three surfaces only get a skimming?
Thanks.
--Rob
Thanks.
--Rob
