Cam Cover Identification
Early cam covers were either a blue metalic or a green for SE version. Never red. Red and black covers came into being when the script Lotus covers were replaced with the block letters across the timing chain part of the cover. Whether or not it is original or copy casting I can not determine, but the color is wrong for this period cover.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
Thank you for the feedback. I suspected that the casting on the interior appeared a bit precise, purposely trimmed to clear a taller cam (or?) with the cut out. So likely an aftermarket/non-original cam cover. When compared to the S2 cam cover from Paul where the inner ridges appear smooth and uniform. On the exterior the two appear very similar, including the Lotus script.
- 1963 S1
Media blast the red paint on the inside of the cam cover. You don?t want the inside painted, it will eventually decompose from the hot oil and blend into your oil. Not ideal.
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
1963 S1 wrote:Thank you for the feedback. I suspected that the casting on the interior appeared a bit precise, purposely trimmed to clear a taller cam (or?) with the cut out. So likely an aftermarket/non-original cam cover. When compared to the S2 cam cover from Paul where the inner ridges appear smooth and uniform. On the exterior the two appear very similar, including the Lotus script.
Smooth inner ridges are the normal situation for original covers as far as i am aware. Your cover is either after market or someone modified an original cover at some stage for some reason
Externally it looks like the right details and Lotus script so externally good as original if that matters to the casual observer. I am sure with some careful measurement of dimensions and an original cover to compare to you could tell if original or after market copy as some original detail would not match based on mould shrinkage dimensions.
It seems to be a feature of aftermarket covers to have an equal size pair of internal webs, a lower or smaller web is required to clear the cam. It can be seen on genuine covers where one web is cast lower, the cut outs I guess are for this reason.
- Craven
