Engine backplate
I acquired my +2 partially disassembled. Now completely stripped and on reassembly. Just trial fitted the new Vought gearbox in the chassis and going to trial assemble the engine to gearbox. Do I need a backplate between engine and gearbox like a typical Ford installation?
There is not one with my pile of bits and the Lotus manual does not show one that I can see.
Dave
Dave
Elan +2
Elise mk 1
Elise mk 1
- Donels
Donels wrote:I acquired my +2 partially disassembled. Now completely stripped and on reassembly. Just trial fitted the new Vought gearbox in the chassis and going to trial assemble the engine to gearbox. Do I need a backplate between engine and gearbox like a typical Ford installation?
There is a backplate, but "backplate" is a bit of a misnomer, it's a thin (about 1mm) sheet steel spacer, with a mating bottom section to close off the bottom of the bell housing.
It can easily be forgotten to be fitted when re-assembling the engine and gearbox.......
68 Elan +2, 70 Elan +2s
Foxie - Coveted Fifth Gear
Dave
On trial fitment it's not so important. On final fitment it is important as the plate helps locate the starter motor accurately.
promotor - Fourth Gear
Dave,
After much faffing about I have convinced myself that this plate is important. The plate has three important holes. The large one that the starter registers in and two smaller holes that locate over the two dowels that protrude from the back of the block and align the gearbox to the engine. This plate locates the axis of the starter with respect to the axis of the crankshaft which in turn ensures that starter pinion engage correctly with the flywheel avoiding nasty noises, jamming and damage.
I believe plates are available from south west lotus. If buying used ensure the three important holes are round and the plate is not distorted, otherwise it may not locate the starter correctly.
Richard Hawkins
Richard Hawkins
- RichardHawkins
Early Twin Cam plate on ebay
https://www.ebay.co.uk/itm/LOTUS-ELAN-E ... SwxJ9cRKDc
Nothing to do with me just thought it might be helpful.
wobblyweb - Second Gear
