Thermostat housing heater control valve thread
I used to work on a gas terminal on instrumentation, we used either ptfe tape or a pipe sealant such as Swac. Both of those joints could be easily unscrewed without resort to heat. The advantage of the ptfe tape in your circumstance is that you can always wrap a couple of extra layers on the thread if the outlet is pointing the wrong way, although better solution would be to run the tapered tap in an extra part turn as you really don?t want more than about 6 layers of thin ptfe tape on a joint.
- Bigbaldybloke
All sorted, thread cleaned up (thanks to Mike for the loan of appropriate tap) new heater valve installed.
Thanks for all the advice.
Malcolm
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
Users browsing this forum: rideaway and 24 guests
