Lotus Elan
Valve guide change. Can I do it myself ?
PostPost by: huggy » Mon Nov 12, 2018 11:43 am
My car smoke (a lot) first 15 seconds when cold or after sitting more than 20 minutes.
Compression are OK.
I think valve guides are worn. It is time for a change.
Can I do it by myself?
Could I find unleaded ones or are they all unleaded now?
Perhaps some are better than other ones? Where's the best place to source them?
If guide are worn do I need to change valvestoo or valves are harder and I just need to check them?
Or there is a specialist able to put this new guides at reasonable cost 200kms around Dover (Live near Calais)
Any help welcome !
Thanks !!
IF IN DOUBT, FLAT OUT !
Colin Mc Rae
huggy
First Gear
First Gear
PostPost by: dougal9887 » Mon Nov 12, 2018 1:21 pm
It's the valve seats, not the guides, which are sometimes changed for running on unleaded. Lotus in fact used a hardened steel seat, as far as I know, and it seems fine with unleaded, at least for the sort of mileages most of these engines see now.
Changing the guides yourself is possible but a challenge and you will need some special equipment.
A suitable mandrel to drift out the old guides without damaging the bores in the head. A means of heating the head evenly to a high temperature (necessary for removal and replacement). A suitable reamer for sizing the new guides once fitted. A valve seat cutter for recutting the seats to suit the new guides.
In summary, this is a job best left to an engineering shop with experience of working on these heads. If the seats do need changed it is not a DIY job.
And yes, your valves will almost certainly need replacing along with the guides. The seats can very likely just be recut.
Sorry I don't know the south coast so cannot recommend anywhere.
Dougal.
dougal9887
PostPost by: RichardHawkins » Mon Nov 12, 2018 8:23 pm
Huggy,
I used Serdi UK in Uxbridge (west of London near Heathrow airport). Whilst talking with them, if I remember correctly, I was told that Serdi is a French company. Might be worth trying to find Serdi in France. I was impressed by the work done for me in the UK.
RIchard Hawkins
RichardHawkins
PostPost by: nmauduit » Mon Nov 12, 2018 8:41 pm
Bonsoir,
as said above, everything is possible but changing the valve guide is easy to mess, then dropping a guide while running will cost a lot more than the little saving achieved by doing it yourself. For my engines, I'm even picky and valve guides is a job I don't give to a random company just by reputation, I prefer old school machinist who has actual experience on Lotus twin cam engines, and discuss the tolerances, the procedure etc. to make sure.
S4SE 36/8198
PostPost by: diablo » Tue Nov 13, 2018 8:09 am
Contact Rectif 2000 in La Garenne Colombes , they use to work on Lotus head ; they are working for me at the moment . Lotus head are a mess , and need special adjustments for the valves / guide assembly .
diablo
PostPost by: alan.barker » Tue Nov 13, 2018 8:24 am
huggy wrote:My car smoke (a lot) first 15 seconds when cold or after sitting more than 20 minutes.
Compression are OK.
Any help welcome !
Thanks !!
Bonjour, i suggest you contact a friend of mine he lives near Yvetot Normandy and does a lot of work on Lotus Engines. Tell him i gave you his E-mail <[email protected]> . info 221 kms 2h18mins
Alan Barker
PostPost by: nmauduit » Tue Nov 13, 2018 9:25 am
diablo wrote:Contact Rectif 2000 in La Garenne Colombes , they use to work on Lotus head ; they are working for me at the moment . Lotus head are a mess , and need special adjustments for the valves / guide assembly .
Hello,
for what it's worth, I only give them non valuable, easy to replace parts, just in case... only day to day vehicle jobs.
ad for the initial query, this would be a bit far for the initial request, so is my machinist of choice for LTC work (300km from Calais) - I'm sure there must be a good one closer to Calais...
S4SE 36/8198
PostPost by: alan.barker » Wed Nov 14, 2018 11:15 am
I just wondered have you removed the Head yet to have a look at the deposits on the backs of the Valves.
Also measured the dia of the Valve stems.
One more question what Engine Oil are you using :wink:
PostPost by: huggy » Fri Nov 23, 2018 11:35 am
alan.barker wrote:I just wondered have you removed the Head yet to have a look at the deposits on the backs of the Valves.
Thanks for your answer Alan,
I didn't removed the head yet.
I'm at the stage I need to choice to live with it as it is (no oil consumption, 20sec smoke..but oil smell and very greasy sparks) or find someone do it it right so trying to find all infos about this subject.
The car run with 20w50: I guess it is correct ?
Colin Mc Rae
huggy
First Gear
First Gear
PostPost by: huggy » Fri Nov 23, 2018 11:39 am
RichardHawkins wrote:Huggy,
RIchard Hawkins
Thanks for your answer Richard,
Serdi seems to be the name of the machine manufacturing.
Uxbridge is not too far for me (I live near Calais) thanks for info.
Colin Mc Rae
huggy
First Gear
First Gear
PostPost by: rgh0 » Fri Nov 23, 2018 12:19 pm
try a 20W 60 synthetic and that will reduce oil leakage down the guides and may make it acceptable for a time and delay the need for a rebuild
PostPost by: alan.barker » Fri Nov 23, 2018 12:47 pm
+1 as usual Rohan,
and if the compressions seem not too bad just get out and drive it :mrgreen: :mrgreen:
PostPost by: huggy » Wed Nov 28, 2018 12:13 pm
Thanks guys ! :mrgreen:
If it is not broken don't fix it !....during few seconds I was pretty sure I was on my Land Rover forum and not Elan one :lol:
Goog idea next oil change will be 20w60
Colin Mc Rae
huggy
First Gear
First Gear
PostPost by: h20hamelan » Wed Nov 28, 2018 5:01 pm
Sounds complicated, doable though.
elan-mods-f31/valve-stem-seals-twincam-t22748.html
W. Kootenays B.C. Canada
Users browsing this forum: madmaxsiegl and 16 guests
